跳转到主内容
2021 Honda HR-V Rear Signal Light Bulb Replacement
你所需要的
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: 步骤 1 中的图像 1,1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 2 中的图像 1,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 2 中的图像 2,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 3 中的图像 1,2 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 4 中的图像 1,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 4 中的图像 2,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 5 中的图像 1,2 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 5 中的图像 2,2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 6 中的图像 1,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 6 中的图像 2,3 2021 Honda HR-V Rear Signal Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
终点
Guadalupe Guevara
于10/26/22注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-8, Briggs Fall 2022 CSU Los Angeles, Team 2-8, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 52
总计 1,214
