跳转到主内容
加入维修社区 - 创建账户
2020 Honda Civic Cabin Lights Replacement
你所需要的
  1. 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: 步骤 1 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: 步骤 1 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: 步骤 1 中的图像 3,3
    • Open the trunk.
    • The cabin light for the trunk will be located on the roof of the trunk.
    询问修复机器人
    添加评论
  2. 2020 Honda Civic Cabin Lights Replacement: 步骤 2 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 2 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 2 中的图像 3,3
    • Wedge a prying tool into the crevice between the light and the roof. Push the tool in to release the light compartment.
    • Carefully pull the light bulb out, using a prying tool if necessary.
    • The light bulb may be hot.
    • Hold the compartment up while you grab your LED light bulb.
    询问修复机器人
    添加评论
  3. 2020 Honda Civic Cabin Lights Replacement: 步骤 3 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 3 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 3 中的图像 3,3
    • Insert the new LED bulb into the light socket until it turns on.
    • When the LED remains constantly on without flickering, the light bulb is correctly inserted into the socket.
    询问修复机器人
    添加评论
  4. 2020 Honda Civic Cabin Lights Replacement: 步骤 4 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 4 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 4 中的图像 3,3
    • Reinstall the light compartment back into position.
    • Align the tabs and push the compartment into the frame until it clicks securely.
    • When the compartment is fully inserted, the cabin light replacement in the trunk is complete. Proceed to the rear passenger cabin light.
    询问修复机器人
    添加评论
  5. 2020 Honda Civic Cabin Lights Replacement: 步骤 5 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 5 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 5 中的图像 3,3
    • The cabin light is located in the rear passenger seats.
    • You need to be inside the car to complete the replacement for this cabin light.
    询问修复机器人
    添加评论
  6. 2020 Honda Civic Cabin Lights Replacement: 步骤 6 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 6 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 6 中的图像 3,3
    • Wedge a prying tool into the corner of the frame.
    • Once the cover pops out, use the end of another prying tool to fully remove it.
    询问修复机器人
    添加评论
  7. 2020 Honda Civic Cabin Lights Replacement: 步骤 7 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 7 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 7 中的图像 3,3
    • With the cover completely removed, begin removing the light bulb.
    • If the light bulb is difficult to remove, use your prying tool to assist in removing the light bulb.
    询问修复机器人
    添加评论
  8. 2020 Honda Civic Cabin Lights Replacement: 步骤 8 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 8 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 8 中的图像 3,3
    • Grab one of your LED light bulbs and insert it into the socket until it is securely in place.
    询问修复机器人
    添加评论
  9. 2020 Honda Civic Cabin Lights Replacement: 步骤 9 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 9 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 9 中的图像 3,3
    • Turn on the switch to ensure the light bulb turns on, indicating the step was completely correctly.
    • After confirming it works, align the cover with the clips and push it into place until you hear a clicking sound.
    询问修复机器人
    添加评论
  10. 2020 Honda Civic Cabin Lights Replacement: 步骤 10 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 10 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 10 中的图像 3,3
    • Move to the to cabin lights in the front of the driver and passenger seat.
    • Each front cabin light has its own switch. We will start with the driver's side light.
    • Wedge the prying tool into the crevice on the inside of the cover.
    • Push carefully to release and remove the cover.
    询问修复机器人
    添加评论
  11. 2020 Honda Civic Cabin Lights Replacement: 步骤 11 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 11 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 11 中的图像 3,3
    • After removing the cover, start pulling out the light bulb from its socket.
    • Once the light bulb is removed, grab your new LED light bulb.
    询问修复机器人
    添加评论
  12. 2020 Honda Civic Cabin Lights Replacement: 步骤 12 中的图像 1,2 2020 Honda Civic Cabin Lights Replacement: 步骤 12 中的图像 2,2
    • Insert your new LED light bulb into the socket until it is completely in place.
    询问修复机器人
    添加评论
  13. 2020 Honda Civic Cabin Lights Replacement: 步骤 13 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 13 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 13 中的图像 3,3
    • Once you are done inserting the new LED light bulb into the socket, begin placing the cover back on.
    • Align the cover with the clips on the frame and push it in until you hear clicking sound.
    • After that, you're done with the driver's side cabin light. Move on to the passenger side.
    询问修复机器人
    添加评论
  14. 2020 Honda Civic Cabin Lights Replacement: 步骤 14 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 14 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 14 中的图像 3,3
    • The passenger side steps are the same as the driver's side.
    • Grab your prying tool, insert it into the wedge on the inside of the cover, and push inward.
    • Once the cover is removed, you can begin removing the light bulb.
    询问修复机器人
    添加评论
  15. 2020 Honda Civic Cabin Lights Replacement: 步骤 15 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 15 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 15 中的图像 3,3
    • After removing the old light bulb, grab your new LED light bulb replacement.
    • With the new light bulb in hand, insert the new light bulb into the socket.
    • Make sure the light bulb is correctly seated in the socket.
    询问修复机器人
    添加评论
  16. 2020 Honda Civic Cabin Lights Replacement: 步骤 16 中的图像 1,2 2020 Honda Civic Cabin Lights Replacement: 步骤 16 中的图像 2,2
    • After inserting the new LED light bulb into the socket. You can begin putting the cover back on.
    • Align the cover with the clips around the frame and push inward.
    • This step is complete when you hear a clicking sound.
    询问修复机器人
    添加评论
  17. 2020 Honda Civic Cabin Lights Replacement: 步骤 17 中的图像 1,3 2020 Honda Civic Cabin Lights Replacement: 步骤 17 中的图像 2,3 2020 Honda Civic Cabin Lights Replacement: 步骤 17 中的图像 3,3
    • Once you have finished, all your cabin lights should look like this when turned on.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 4-55, Harris Fall 2024 CSU Los Angeles, Team 4-55, Harris Fall 2024 的会员
CSULA-HARRIS-F24S4G55
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 72
总计 957
