跳转到主内容
2020 Dodge Charger Windshield Wiper Replacement
你所需要的
  1. 2020 Dodge Charger Windshield Wiper Replacement, Windshield Wiper: 步骤 1 中的图像 1,2 2020 Dodge Charger Windshield Wiper Replacement, Windshield Wiper: 步骤 1 中的图像 2,2
    • Grabbing at the bottom, pull the wiper arm up and away from the windshield, until it stands fully in the air.
    • The wiper arm is separate from the blade, and sits connected towards the bottom end of the windshield. A quarter turn puts it fully upright.
  2. 2020 Dodge Charger Windshield Wiper Replacement: 步骤 2 中的图像 1,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 2 中的图像 2,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 2 中的图像 3,3
    • Flip up on the lock tab.
    • Tilt the lower half of the blade away from the arm.
    • The lock tab sits at the end of the arm and on the blade; unlocking it allows the blade to be moved. The bottom half should come slightly towards the user when rotated.
  3. 2020 Dodge Charger Windshield Wiper Replacement: 步骤 3 中的图像 1,2 2020 Dodge Charger Windshield Wiper Replacement: 步骤 3 中的图像 2,2
    • Grip the base of the arm with one hand.
    • Use the other hand to grab the blade above the unlocked tab.
    • Push the blade down into the arm, then away from the wiper arm.
    • The arm should be held steady. The small area left to the unlocked tab is where the blade is first pushed; then it can be removed by pushing towards the windshield. This reveals the hook on the wiper arm and the blade is fully removed.
  4. 2020 Dodge Charger Windshield Wiper Replacement: 步骤 4 中的图像 1,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 4 中的图像 2,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 4 中的图像 3,3
    • Open the locking tab on the replacement blade.
    • Use the opening under the tab and insert the blade into the hook.
    • Pull the blade up into the hook.
    • The opening on the blade is where the hook is inserted; this is the previous step in reverse. The blade should be pushed in and up as far as it can.
  5. 2020 Dodge Charger Windshield Wiper Replacement: 步骤 5 中的图像 1,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 5 中的图像 2,3 2020 Dodge Charger Windshield Wiper Replacement: 步骤 5 中的图像 3,3
    • Close the lock tab and press it.
    • Grab the wiper arm and lower it onto the glass.
    • Pressing the lock tab ensures it is on and locked properly. After placing the wiper onto the screen, the replacement is complete.
结论
After completing all the necessary steps in this guide, you should have been able to successfully take off and place new wiper blades for a 2020 Dodge Charger. If there are any issues persisting with new blades or removing current ones, please consult the owner’s manual.
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 1,267
