简介
如果你的触控板损坏或需要卸下以方便接触电池,请按照以下步骤操作。
为了你的安全,在开始此程序之前,请将 MacBook Pro 的电池电量放电至 25% 以下。如果意外刺破充电的锂离子电池,可能会引发危险且无法控制的火灾。
你所需要的
将底壳用力拉向 MacBook 的正面(远离铰链区域),以分离固定下壳的最后一个夹子。
Be mindful of finger placement as the inside edges of the case are very sharp and may cut you.
literally just cut myself
I used the suction cup to pull/slide the lower case from the back clips
This is probably the most difficult step. It doesn't come easily, you have to be careful but very firm and apply plenty of force. The edges are somewhat sharp, but I didn't cut myself. Just don't slide your fingers along the edges. I had the best luck orienting the computer in portrait (like the pictures) and pushing on the front right edge of the main chasis with my right hand fingers while pushing the opposite direction on the bottom lid with my left hand fingers (place your fingers right in the crack of the hinge).
使用T5 Torx 螺丝刀,以删除3.7 mm 煎饼螺丝固定电池电源接口。
io ho trovato un Torx T4 invece del T5.
Ciao Stefano! Grazie per il commento. Infatti c’è sempre una certa tolleranza fra il cacciavite e la testa delle viti. Quindi è possibile che un cacciavite più grande o più piccolo sia più “comodo” in certi casi. Buona riparazione!
konnte diese Verbindung nicht lösen. Zu sehr angezogen
轻轻地断开电池接口,用小铲轻轻地拔出电池。
将接口抬得足够高,使其与插座保持分离。如果在维修过程中意外接触,可能会损坏 MacBook Pro。
Please save yourself a pile of money and read this before doing this step: I bricked my MacBook by not being extremely careful and making sure to NOT touch the connector together as I took it apart. Ouch ouch ouch. 😫
准备一个 iOpener 并将其放在触控板带状电缆的顶部约一分钟,以软化将触控板带状电缆固定到电池顶部的粘合剂。
如果你没有 iOpener,请使用吹风机加热电缆。电缆应该是温暖的,但不能太热而无法触摸。小心不要使电池过热。
The iOpener is not really needed for this step. The ribbon cable peels off without any bending with just a light pull.
I concur with Mark. Just a light pull, easy does it.
Mine didn't come off easily, it definitely needed heating
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
***要重新组装你的设备,请按逆序执行上述步骤。***
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?尝试一些基本的 故障排除 或搜索我们的 [链接|https://www.ifixit.com/Answers/Device/Ma... 20Ports%202020|论坛]寻求帮助。
3等其他人完成本指南。
由衷感谢以下译者:
91%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Does anyone knows, if I follow this procedure carefully just to clean the inside of the trackpad, if it will void my warranty? Or there isn’t any way for Apple to know that I’ve done this?
Short answer: Yes... Reason?: Their name's Apple
Thanks for this guide, it was excellent – easy to follow. I used the iFixit Essential Electronics Toolkit for the first time to do this and the box lid with moulded grid proved very useful for keeping the screws mapped to where they belonged in the laptop.
I would suggest adding that the laptop must be connected to power to restart it after the repair. Pressing the power button to no response induced a small panic but plugging it in brought it right back.
Is it completely necessary to disconnect the battery? 8 - 14 is it absolutely necessary?
Yes, cuz your body can transfer electricity and if you accidentally touch a circuit while the batterie is still connected, the possibility of damaging the MacBook exist.
I followed direction and it was very good but some how my keyboard stop working. I looked at every thing that I did and nothing came lose. The touch screen on the keyboard is working and I see light under it but no typing off the laptop keyboard, Any suggestion?
I'm about to attempt this repair, but I've heard about Apple disabling features when replacing with any hardware that was not originally tied to the device, especially with iPhones. Is this also the case with the 2020 M1 13" MBP? Would a trackpad replacement trigger the T2 chip?
You shouldn't have any problems or lose features after replacing the trackpad. If you wanted to replace the Touch ID power button though, for example, the replacement would be tied to another logic board—meaning you'd need to replace them together.
I use a empty egg carton to place screws in in the order of removal from computer
robert - 回复
That's a good idea Robert!
Tom Kingsley -
