简介
使用本指南,借助带有粘合剂去除剂的 iFixit 套装,安全地从 MacBook Pro 上拆下胶合电池。粘合剂去除剂会溶解固定电池的粘合剂,让您轻松去除电池。
iFixit 粘合剂去除剂易燃。 在通风良好的区域执行此程序。在此过程中,请勿吸烟或在明火附近工作。
更换电池不需要拆下主板,这使得这个过程变得更加容易。
为最大程度地降低损坏风险,请在开始此过程之前打开 MacBook 并让电池完全放电。 如果不小心刺破充电的锂离子电池,可能会引发危险且无法控制的火灾。如果您的电池膨胀,采取额外的预防措施。
注意:粘合剂去除剂会损坏某些塑料。遵循所有说明并注意涂抹粘合剂去除剂的位置。
本指南中的一些照片来自不同的模型,可能包含轻微的视觉差异,但不会影响指南过程。
你所需要的
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?尝试一些基本的 故障排除 或搜索我们的 [链接|https://www.ifixit.com/Answers/Device/Ma... 20Ports%202020|论坛]寻求帮助。
15等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
3指南评论
Just completed a battery swap on my m1 macbook pro 13' early 2020 with the battery purchased from Ifixit. Guide was incredibly helpful and eased my nerves putting my laptop on the line doing my own repair vs paying the 600 bucks my local repair shop wanted.
I did notice that since this guides writing the adhesive removal bottle has been re-designed with a less precise applicator which made the process more finicky and messy then what was shown. thankfully another commenter left some advice that helped
During re-assembly i found getting the bottom shell back on was the most finicky and difficult part of the entire process, needed to refer to another YouTube video to know how best to get it back on, Some detail on the guide here would have been appreciated.
All and all fantastic guide and service, very happy and i will definitely turn to Ifixit for my future repair needs. Love from Australia <3
The removal process of the old battery was quite tricky and time consuming, the centre cell is the most difficult to remove, patience is key though, you don't want to slip and damage the logic board!
After removing the old battery, I found it was best to dry up as much as possible the old isopropyl alcohol then you can roll the adhesive strips off with your thumb/finger. For me, this was more successful than trying to scrape them while wet.
Last time, on a different MacBook I used another brand of battery, which was a little cheaper, it will be interesting to see the long term lifespan on this iFixit one!
