简介
使用本指南,借助带有粘合剂去除剂的 iFixit 套装,安全地从 MacBook Pro 上拆下胶合电池。粘合剂去除剂会溶解固定电池的粘合剂,让你轻松去除电池。
更换电池不需要拆下主板,这使得这个过程变得更加容易。
为最大程度地降低损坏风险,请在开始此过程之前打开 MacBook 并让电池完全放电。 如果不小心刺破充电的锂离子电池,可能会引发危险且无法控制的火灾。如果您的电池膨胀,采取额外的预防措施。
iFixit 粘合剂去除剂易燃。 在通风良好的区域执行此程序。在此过程中,请勿吸烟或在明火附近工作。
注意:粘合剂去除剂会损坏某些塑料。遵循所有说明并注意涂抹粘合剂去除剂的位置。
本指南中的一些照片来自不同的模型,可能包含轻微的视觉差异,但不会影响指南过程。
你所需要的
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?尝试一些基本的 故障排除 或搜索我们的 [链接|https://www.ifixit.com/Answers/Device/Ma... 20Ports%20Late%202020|论坛]寻求帮助。
14等其他人完成本指南。
由衷感谢以下译者:
75%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
10条评论
Thanks for the guide 👍🏻
Can’t see a link to a new battery though - is it available on iFixit? Which one should I get as a replacement?
Thank you.
Do you have any tips on aligning the trackpad during reinstallation so it’s even on all sides?
Scott, I recommend tightening the trackpad screws until they're finger-tight, open the MacBook and center the trackpad, then tighten the screws the rest of the way down. Best of luck!
Any tips to find a good battery? iFixit doesn’t seem to stock them?
Definitely need to get the adhesive remover. I did it without and used Isopropyl Alcohol and it didn’t make much of difference so I had to work very hard with a credit card to free the batter which also had me bang the motherboard a few times. So get the remover. I wish Ifixit would just sell the alcohol only and not the whole kit. Everyone doesn’t need all the added stuff. But everything so working fine despite the extra work.
