跳转到主内容
2019 Mitsubishi Mirage Cabin Air Filter Replacement
你所需要的
  1. 2019 Mitsubishi Mirage Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,2 2019 Mitsubishi Mirage Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,2
    • Locate the glove box near the front passenger seat in the vehicle.
  2. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 2 中的图像 1,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 2 中的图像 2,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 2 中的图像 3,3
    • Open the glove box using the designated handle and remove any stored items.
  3. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 3 中的图像 1,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 3 中的图像 2,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 3 中的图像 3,3
    • Look at the top left and right of the glovebox. Here, you will see tabs attached to both sides.
    • Using both hands, push each side of the glove box inward, making the tabs unfasten from their designated clips. The glove box will now fold down.
  4. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 4 中的图像 1,2 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 4 中的图像 2,2
    • Pinch the safety clip on the right side of the filter and pull the cover off.
  5. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 5 中的图像 1,1
    • Pull the cabin air filter out of the compartment and set it to the side.
  6. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 6 中的图像 1,2 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 6 中的图像 2,2
    • Place a new air filter inside the cabin air filter compartment right side up.
    • Refer to cabin air filter packaging.
    • Replace the cabin air filter cover. Ensure that the cover is slid on correctly and that the safety clip is secured on the right before moving on.
  7. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 7 中的图像 1,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 7 中的图像 2,3 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 7 中的图像 3,3
    • Grab both sides of the glove box near the top just as you did in step 3.
    • Push the tabs inward and push the glove box back into place.
    • Ensure the tabs are secured in their designated clips before closing the glove box.
    • You will hear a "click" sound when the tabs are in place.
  8. 2019 Mitsubishi Mirage Cabin Air Filter Replacement: 步骤 8 中的图像 1,1
    • Dispose of the used air filter properly.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 53
总计 130
