跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
你所需要的
  1. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 禁用自动重启: 步骤 1 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 禁用自动重启: 步骤 1 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 禁用自动重启: 步骤 1 中的图像 3,3
    • 在开始此步骤之前,你必须禁用 Mac 的自动重启功能。自动重启功能会让 MacBook 在掀开盖子时自动开机。这个功能在拆卸过程中也可能会被意外触发。使用本指南或按照下面的简要说明来禁用自动启动。这项指令可能并不适用于所有 Mac。
    • 开机,并打开终端
    • 将以下命令复制粘贴到(或完全键入)终端窗口中:
    • sudo nvram AutoBoot=%00
    • [回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return
    • 你现在可以安全地关闭Mac电脑,并打开底壳,它不会再意外启动了。
    • 当修理完成、成功组装复原Mac电脑后,在「终端」中使用以下命令来启用「自动启动」功能:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - 回复
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - 回复
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - 回复
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - 回复
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - 回复
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - 回复
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - 回复
    Not able to do that with damaged screen
    richardjgreen - 回复
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - 回复
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - 回复
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - 回复
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - 回复
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - 回复
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - 回复
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - 回复
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - 回复
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - 回复
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - 回复
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - 回复
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - 回复
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - 回复
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - 回复
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - 回复
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - 回复
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - 回复
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 底壳: 步骤 2 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 底壳: 步骤 2 中的图像 2,2
    • 开始之前,请完全关闭并拔下 MacBook Pro的电源插头。
    • 关闭显示屏并翻转整个笔记本电脑。使用P5 五角螺丝刀卸下固定底壳的六个螺丝,长度如下:
    • 四颗 4.7 mm 螺丝
    • 两颗 6.6 mm 螺丝
    • 在拆卸螺钉时请注意螺丝的方向 —— 需要以微小的角度重新安装。
    • 在整个维修过程中,记录每个螺丝并确保它准确地回到原来的位置以避免损坏你的设备。
    I miss a printable template to leave the screws and removed parts on it for future identification when reassembly, linked maybe with the location in the Macbook, or with the number of the step.
    Juan Ignacio Fernández García - 回复
  3. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 3 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 3 中的图像 2,2
    • 将抽吸手柄按到底壳前缘附近,螺丝孔之间。
    • 提起吸力手柄,足以打开底壳下方的小间隙。
    Throw away this suction cup and get another. It just doesn't work! Luckily I had one that does work in my tool kit.
    Greek Taylor - 回复
  4. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 4 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 4 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 4 中的图像 3,3
    • 将三角撬片的角落滑入刚刚在底壳下方形成的间隙中。
    • 将三角撬片滑动到最近的角落,然后在MacBook Pro 侧面的一半处滑动。
    • 这将打开第一个固定底壳的隐藏夹子。你应该感受并听到弹出声。
  5. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 5 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 5 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 5 中的图像 3,3
    • 在对面重复上一步,使用三角撬片打开第二个夹扣。
  6. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 6 中的图像 1,1
    • 抬起底壳的前缘(与显示屏合页相对的一侧),使指尖滑到下面并抓住它。
    • 如果无法抓住,则盖子中间附近的两个额外隐藏的夹子可以在此时自由弹出。
    • 不要抬得太高,也不要试图拆下底壳。
  7. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 7 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 7 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 7 中的图像 3,3
    • 将底壳牢固地拉向 MacBook 的前部(远离合页区域),以分离固定底壳的最后一个夹子。
    • 首先在一个角落拉,然后在另一个角落拉。
    • 往拉到一边 —— 不要往上。
    • 此处需要很大的力气。
    With the amount of force needed to carefully pull the back panel out, this caused the back panel to scratch the battery. I don't see or hear any expansion, but this still has me concerned.
    gladgura - 回复
    this step must require a lot of force. I tried to pull it with the plastic hookie thing from the ifixit set by hooking it in one of the screw holes — the tip of the hookie thing broke.
    Oleksii Toldaiev - 回复
    The amount of force required for removing the bottom cover is absolutely ridiculous. Almost feels like i'm about to push my MacBook towards the wall the second it comes off.
    Be careful, I ended up breaking 2 grounding pins on the motherboard last time I tried opening my computer up.
    techtalkf - 回复
    PLEASE DON'T PULL!!!
    Instead just gently push with plastic pick from the other side (where vents outputs are) towards the center... Cover will very easily open that way.
    I hope iFixit will correct this step.
    Kamil Roman - 回复
    Came here to share exactly this.
    Robert -
    That's definitely how this step should be done. Thanks!
    VovS -
    If someone has a photo to share regarding this comment, it might be very useful. Thanks.
    Mark Cohen -
    I used a screwdriver at 45 degrees angle and pushed the cover from the hinges, it worked really smooth. I had it close to the corners.
    Martin Lundgren - 回复
    Yeah, definitely don't pull; if you do, wear protective gloves. Mine was stuck so strongly that I just cut my palm quite deep.
    Kirill Chernov (PowerDoge) - 回复
    You would think ifixit would investigate why the last step required them to pull with great force to remove the bottom case lid as the solution.
    It's counter-intuitive to use an excessive method to remove a part.
    There's always an easier way. It's frustrating because you can't see inside.
    Cary B - 回复
    Using the iFixit opening Tool in the hinge opening required close to no force to open.
    Anders Markstrom - 回复
    Ah... after attempting to 'pull' this rear cover off, to no avail, I tried to coax the cover off with a nylon pry tool. MUCH better! iFixIt will do well to amend it's recommendation to 'pull' this cover in any way. All I wanted to do was a little house cleaning and exorcize the dust bunnies that took up residence in my MBP's fans. Today is much quieter. Thank you all for pointing out the obvious.
    P.C. - 回复
  8. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 8 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 8 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 8 中的图像 3,3
    • 取下底壳。
    • 要重新安装底壳:
    • 将其固定到位并将滑动夹子对准显示屏合页附近。向下按并将盖子滑向合页。它应该在夹扣合上时停止滑动。
    • 当滑动夹完全啮合且下壳看起来正确对齐时,用力向下按下底壳以啮合四个隐藏的夹子。你应该感觉到并听到它们啮合到位。
    If I had it all to do over, again, I would blow out the dust with compressed air at this point. During the disassembly, I kept encountering little dust bunnies, and I was very worried that one would get caught in one of the connectors when I plugged everything back up (which wouldn’t get discovered until I put it all back together and tried out all of the components).
    Joe Emenaker - 回复
  9. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 电池接口: 步骤 9 中的图像 1,1
    • 剥离并取下最靠近电池的主板边缘的大矩形电池板盖。
    • 如果盖子不易剥落,请使用 iOpener,吹风机或热风枪轻轻加热以软化下面的粘合剂,然后再试一次。
    • 如果在重新组装时盖子没有牢固就位,请尝试将其旋转180度。必须正确定位,以使下面的粘合垫与板上螺丝接触。
    i need a ziff connector flap for step 10
    Gregg Gorin - 回复
  10. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 10 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 10 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 10 中的图像 3,3
    • 剥去覆盖电池板数据线接口的任何胶带。
    • 使用撬棒轻轻撬起电池板数据线的 ZIF 接口上的锁定盖板。
  11. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 11 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 11 中的图像 2,2
    • 将电池板数据线从插槽中滑出,将其断开。
    • 沿电缆方向平行于主板滑动。
  12. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 12 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 12 中的图像 2,2
    • 撬起并断开电池板数据线另一端接口上的锁定翻盖。
  13. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 13 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 13 中的图像 2,2
    • 将电池板数据线从电池板上的插座中滑出,然后将其完全取出。
    • 注意不要向后或倒置安装此电缆。正确安装后,白色液体指示器标签应朝上,直接放置在电池电源接口螺丝上方。
    Bonjour, super Tuto, petite question elle sert a quoi cette nappe , et quesqui se passe si elle est pas branché ?
    Jorgio -aigleBrun- - 回复
  14. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 14 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 14 中的图像 2,2
    • 使用 T5 Torx 螺丝刀卸下固定电池电源接口的3.7 mm 薄饼螺丝。
  15. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 15 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 15 中的图像 2,2
    • 使用撬棒提起电池电源接口,断开电池。
    • 在维修时,将接口抬高到足以使其与插座分离。如果意外接触,可能会损坏你的MacBook Pro。
    Put a little bit of insulating tape over the terminal to be safe.
    Brian Tibbels - 回复
    Agreed - once this is back in place, the system is energized, you run the risk of creating little sparks or worse if metal objects such as cover brackets accidentally touch areas of the logic board.
    bkbkbk - 回复
  16. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 显示屏: 步骤 16 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换, 显示屏: 步骤 16 中的图像 2,2
    • 使用 T3 Torx 螺丝刀卸下将盖板固定在显示板柔性电缆上的两颗3.5毫米螺丝。
    • 移除显示板柔性电缆盖子。
    T3 or T4? I almost damage the screw trying with the T3.
    Christian Polychroniadis - 回复
    I’d say T4 as T3 was definitely too small
    David Smith -
    T3 worked fine!
    Martin - 回复
  17. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 17 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 17 中的图像 2,2
    • 使用 T3 Torx 螺丝刀移除固定显示板电缆连接器支架的两个 1.7 mm 螺丝。
    • 从显示板电缆接口上拆下支架。
    Step requires T4 Torx instead of T3 Torx.
    Banana - 回复
    I damaged the screw trying to use a T3. Now I am screwed.
    markshain - 回复
  18. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 18 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 18 中的图像 2,2
    • 用撬棒直接撬起以断开显示板柔性电缆。
  19. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 19 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 19 中的图像 2,2
    • 使用 T3 Torx螺丝刀卸下固定每个盖子的四个2.0 mm 螺丝(总共四个螺丝)。
  20. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 20 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 20 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 20 中的图像 3,3
    • 移除盖子。
  21. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 21 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 21 中的图像 2,2
    • 使用 T5 Torx 螺丝刀拆下固定天线电缆束的单个 2.9 mm 螺丝。
  22. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 22 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 22 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 22 中的图像 3,3
    • 从插座中垂直向上撬开所有三根天线电缆。
    • 将镊子或撬棒的扁平端滑到每根电缆下方,直到它靠近插座,然后轻轻扭动或撬起以断开连接。
    • 要重新连接每根电缆,请将接口直接对准其插槽,然后向下按,使其卡入到位。
  23. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 23 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 23 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 23 中的图像 3,3
    • 使用 T5 Torx 螺丝刀卸下固定显示板的四颗3.3毫米螺丝。
    • 在重新安装这些螺丝之前:
    • 确保显示板柔性电缆位于电路板顶部,而不是位于电路板下方。
    When reassembling, I found that I had to press in on the outer edge of the antenna (top edge when looking at the picture) at the midpoint between the left 8 screws and the right 8 screws as I screwed the display board screws in. I found that the outside antenna edge would otherwise rub against the display halfway through opening it making a pop sound. Installing this way fixed the problem.
    Robert Scheid - 回复
  24. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 24 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 24 中的图像 2,2
    • 使用 P2 五角螺丝刀卸下固定天线组件的16个1.5 mm 螺丝。
    I’m having difficulty removing the screws. I’m not sure if the p2 screwdriver is defective but I am now stuck at this step.
    Sonia Carrillo-Ramirez - 回复
    i can only seem to get 2/3 of the screws out
    Leif - 回复
    After giving up, someone else got them all out in about 10 sec using the Apple pentalope screwdriver, specific to Apple.
    Leif - 回复
    The 4 of Pentalobe5 screws in the middle between the two sets of 8 screws also need to be removed.
    pboyle - 回复
    Oooops, wrong, those are 4 of T5 screws in the middle
    pboyle - 回复
    Ok, wrong again. Step 23 is this set of 4 of T5s.
    The step that is missing is removing the set of 4 of T3s that hold the display flexes and springs.
    Sorry about the mess of corrections.
    pboyle - 回复
    We had 4 MBP's that I removed the displays from. On this step, I stripped a 'middle' screw on each side.
    On the second one, I also noticed the middle screws didn't exactly want to easily come loose as I worked my way down the row.
    I wound up putting all screws back in, loosened then tightened the screw on the opposite end, then removed the two in the middle (without issue), then an outside screw going back and forth, until I just had one on each end. Since I had already removed and replaced them, they came out without issue.
    I used this method on the remaining 2 MBP's and had no further issues.
    YMMV and it may not even be necessary. Just seemed removing the screws from end to end put enough pressure on the remaining ones that they were harder to remove. Whereas a patterned removal seemed to resolve that 'issue'.
    fozman2 - 回复
  25. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 25 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 25 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 25 中的图像 3,3
    • 使用三角撬片撬起天线组件并将其与MacBook Pro分开。
    • 注意中间部分的精致带状电缆。避免从一侧到另一侧滑动挡板,以免损坏电缆。
  26. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 26 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 26 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 26 中的图像 3,3
    • 小心地卸下天线组件,同时将天线电缆束从散热器下方取出。
    • 在重新组装过程中,轻轻地将电缆束夹在一起,并将其引导到热管下方的正确位置。如果需要,请使用你的工具来指导它,但不要强制它。
  27. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 27 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 27 中的图像 2,2
    • 使用 T3 Torx 螺丝刀卸下固定显示屏电缆盖弹簧的四个 3.9 mm 螺丝。
    Used a T4 here.
    PCICS - 回复
    T4 for me (MBP 2018 15’)
    stephane - 回复
  28. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 28 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 28 中的图像 2,2
    • 使用T8 Torx 螺丝刀从每个合页上卸下两个4.9 mm 螺丝(总共四个螺丝)。
    • 每个合页都有第三个螺丝,你现在应该留在原位。
  29. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 29 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 29 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 29 中的图像 3,3
    • 重新组装时,首先安装合页螺丝,不要拧紧。然后调整屏幕,直到它正确居中并在每一侧对齐。最后,拧紧螺丝。
    • 如果屏幕在打开时发出咔嗒声或卡扣,请松开合页螺丝并调整对齐方式。确保屏幕不会位于太远的位置,或者在打开和关闭时可能会卡在机体上。
    • 如果需要,可在螺纹上添加一点蓝色螺纹锁固剂,以防止它们随时间松动。
  30. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 30 中的图像 1,2 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 30 中的图像 2,2
    • 如果你打算重新使用屏幕,请将其打开并在每个合页正上方的玻璃板上贴一条胶带。这有助于防止玻璃在下一步中被划伤。
    • 完全打开屏幕,将MacBook Pro放在一边。
  31. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 31 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 31 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 31 中的图像 3,3
    • 使用T8 Torx螺丝刀卸下剩余的两个4.9 mm 合页螺丝(每个合页一个)。
    • 最后卸下最上面的螺丝,用一只手稳定 MacBook Pro 的两半,确保它们不会分离并意外掉落。
  32. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 32 中的图像 1,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 32 中的图像 2,3 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 32 中的图像 3,3
    • 牢牢抓住MacBook Pro的屏幕和主体。在这一步中,任何一半都会意外跌落。
    • 将MacBook Pro 的两半推到一起,以便合页可以从机箱中的凹槽中抬起。
    • 将MacBook Pro的主体推离你,同时将屏幕拉向你以将其分开。
  33. 2019 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换: 步骤 33 中的图像 1,1
    • 移除显示屏。
结论
将新的更换配件与原始配件进行比较 —— 在​​安装之前,你可能需要转移剩余配件或从新配件上移除粘合剂背衬。
要重新组装设备,请按逆序执行上述步骤。
请把电子废料带到 R2 或 e-Stewards 认证的回收商
维修没有按计划进行?请查阅论坛 寻求帮助。
17等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
427,901 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
8条评论
This is such a noob question but how do I marked that”I did this repair”.
Andres Torres - 回复
Do you have a link to a Apple Screen?
Paul - 回复
wo bekommt man denn einen MacBook pro 15 zoll 2019 Display her?
drumma15 - 回复
I followed all of these steps to replace my display and when I put it all back together my Mac would only turn on when it was plugged into the wall. So the new display works fine but it doesn’t seem to recognize the battery at all. Has anyone run into this problem and know what the issue might be?
Jason - 回复
Jason - did you plug the battery connector and cable back in correctly?
Kevin Gill - 回复
I need anew battery connector mine i missing one end maybe …
my screen was replaced by a dealer and I found missing screws and the battery board data cable was glued so hard with a piece of tape when I pulled it out one side showed connection wires the other was nothing ,what don I do when I get a new one (if i can get one?..,,,
Robert Reser - 回复
i am confused by the direction and how difficult such a simple step can stop me cold the battery connector is very fragile and i was not prepared for the outcome
i need help what can i do next. Thanks
Robert Reser
Robert Reser - 回复
Can this model MacBook Pro 2019 A1990 work as a headless Mac
KrazyKaleb - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 100
过去 30 天: 512
总计 47,790
