简介
使用本指南来更换有问题的触控板,或者在维护电池时简单地临时拆卸触控板。
在你开始这个程序之前,“为了你的安全,把你的MacBook Pro电池放电低于25%”。充电的锂离子电池如果不小心被戳破,可能引发危险的火灾。
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
将新的替换部件与原始部件进行比较 - 在安装之前,你可能需要转移剩余的组件或去除新部件上的背胶。
要重新组装你的设备,请按逆序执行上述步骤。
把你的电子垃圾送到R2或e-Stewards认证回收商。
修理没有按计划进行?查看我们的社区来获得故障排除帮助。
9等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
一条评论
I have a macbook pro 16" from 2019, it did not give me a haptic response, the Force Touch is sensitive to touch and pressure but there was no sensation of "click" or vibration, I disassembled the mac and the trackpad out of pure curiosity, and when closing and turn on the mac, the trackpad was completely unusable as well as the keyboard and the fans at full, I already tried to restore PRAM and SMC with an external keyboard and nothing worked, I already started in safe mode and neither. I reopen it to verify all the grants but there is nothing visibly wrong. Please Help...
