跳转到主内容
2018 Toyota Corolla LE Battery Replacement
你所需要的
  1. 2018 Toyota Corolla LE Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Caution: Wear gloves and a mask as a basic safety precaution to avoid inhaling or touching toxins which may be harmful to your lungs.
    • Car batteries have a voltage comparable to small Duracell batteries; don't work in fear of being shocked.
    • Open the hood and locate your battery.
  2. 2018 Toyota Corolla LE Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from the brace securing the battery.
  3. 2018 Toyota Corolla LE Battery Replacement: 步骤 3 中的图像 1,3 2018 Toyota Corolla LE Battery Replacement: 步骤 3 中的图像 2,3 2018 Toyota Corolla LE Battery Replacement: 步骤 3 中的图像 3,3
    • Disconnect the connector on the right with no coloring or cap.
    • Remove the vertically facing screw to disconnect the battery.
    • Loosen the clamp on the side directly connected to the battery.
    • Move both away from the battery once they've been disconnected/loosened enough to disconnect.
  4. 2018 Toyota Corolla LE Battery Replacement: 步骤 4 中的图像 1,3 2018 Toyota Corolla LE Battery Replacement: 步骤 4 中的图像 2,3 2018 Toyota Corolla LE Battery Replacement: 步骤 4 中的图像 3,3
    • After removing the red cap on the second connector follow the same process you did with the right.
    • Remove the vertical screw first.
    • Loosen the horizontal screw on the side in order to fully free the battery.
  5. 2018 Toyota Corolla LE Battery Replacement: 步骤 5 中的图像 1,3 2018 Toyota Corolla LE Battery Replacement: 步骤 5 中的图像 2,3 2018 Toyota Corolla LE Battery Replacement: 步骤 5 中的图像 3,3
    • Car batteries are quite heavy so get ready to give a good lift.
    • Ensure you have a good grip on both ends and pull up both sides at once; you don't want the battery to tilt to one side
  6. 2018 Toyota Corolla LE Battery Replacement: 步骤 6 中的图像 1,2 2018 Toyota Corolla LE Battery Replacement: 步骤 6 中的图像 2,2
    • Pull out the tray that was holding the battery.
    • Clean off any dust or corrosion formed from use.
    • Place it back using the points on it to indicate how to fit it back in.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 84
总计 414
