简介
If your Nissan Murano 2018 car key fob has stopped starting the engine of the car, then the key battery is most likely dead, which requires replacement.
A functional battery will properly lock and unlock the car without any difficulty. On most occasions, the car will alert the driver to the battery being low before it dies entirely.
This guide will show an easy seven minute repair to change out the battery in the key fob to keep the vehicle running.
你所需要的
Pull the button on the back of the key fob from right to left while pulling the hoop on the top.
Completely remove the key from the fob.
Point the fob vertically towards you and find the groove between the front and the back.
Carefully, using an iFixit opening tool or similar household object, pry open the fob by sliding the flat end into the groove.
Slide your opening tool around the entire fob following the groove.
Pull apart the two main pieces.
