跳转到主内容
2018 MacBook Pro 13" Touch Bar Replacement
你所需要的
  1. 2018 MacBook Pro 13" Touch Bar Replacement, Disable Auto Boot: 步骤 1 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Disable Auto Boot: 步骤 1 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Disable Auto Boot: 步骤 1 中的图像 3,3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • 'sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command (typed into Terminal, as shown above):
    • sudo nvram AutoBoot=%03
  2. 2018 MacBook Pro 13" Touch Bar Replacement, Remove the pentalobe screws: 步骤 2 中的图像 1,1
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. 2018 MacBook Pro 13" Touch Bar Replacement, Open a gap using a suction cup: 步骤 3 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Open a gap using a suction cup: 步骤 3 中的图像 2,2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. 2018 MacBook Pro 13" Touch Bar Replacement, Separate the clips: 步骤 4 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Separate the clips: 步骤 4 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Separate the clips: 步骤 4 中的图像 3,3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 5 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 5 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 5 中的图像 3,3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 6 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 6 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 6 中的图像 3,3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 7 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 7 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 7 中的图像 3,3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. 2018 MacBook Pro 13" Touch Bar Replacement, Remove the lower case: 步骤 8 中的图像 1,1
    • Remove the lower case.
  9. 2018 MacBook Pro 13" Touch Bar Replacement, Uncover the battery connector: 步骤 9 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Uncover the battery connector: 步骤 9 中的图像 2,2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 10 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 10 中的图像 2,2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 11 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 11 中的图像 2,2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  12. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 12 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 12 中的图像 2,2
    • Fold the battery board data cable to the side and out of the way.
  13. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 13 中的图像 1,1
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. 2018 MacBook Pro 13" Touch Bar Replacement, Disconnect the battery: 步骤 14 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Disconnect the battery: 步骤 14 中的图像 2,2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. 2018 MacBook Pro 13" Touch Bar Replacement, Remove the trackpad connector screws: 步骤 15 中的图像 1,1
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  16. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  17. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 17 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 17 中的图像 2,2
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  18. 2018 MacBook Pro 13" Touch Bar Replacement, Disconnect keyboard connector: 步骤 18 中的图像 1,1
    • Use a T3 Torx driver to remove the two screws.
    • Two T3 Torx Screws.
  19. 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Left speaker cables: 步骤 19 中的图像 1,1
    • Carefully peel back the black tape to reveal the ZIF connector.
    • Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
    • Repeat this process with the newly revealed connector.
    • The two screws that are outlined in yellow are not relevant to this step and are marked on the board itself. For this step, yellow corresponds to the yellow rectangle in the image.
  20. 2018 MacBook Pro 13" Touch Bar Replacement, Unplug left Thunderbolt ports: 步骤 20 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Unplug left Thunderbolt ports: 步骤 20 中的图像 2,2
    • Once the screw have been removed carefully remove the metal shield.
    • Under the metal shield there is a connector, carefully unplug it.
  21. 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Touch ID and Auxiliary port: 步骤 21 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Touch ID and Auxiliary port: 步骤 21 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Touch ID and Auxiliary port: 步骤 21 中的图像 3,3
    • Use a T4 Torx driver to remove the two screws.
    • Two T4 Torx screws.
    • Carefully remove the metal shield.
    • Under the metal shield you will find two connectors, carefully unclip them.
    • The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
    • The adhered cable is very thin and delicate so don't rush it and take your time.
  22. 2018 MacBook Pro 13" Touch Bar Replacement, Disconnecting the display connector: 步骤 22 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Disconnecting the display connector: 步骤 22 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Disconnecting the display connector: 步骤 22 中的图像 3,3
    • Use a T3 Torx driver to remove the four screws.
    • 4 T3 Torx screws.
    • Once the screws are removed carefully remove the metal shields.
    • Carefully unclip the connector.
  23. 2018 MacBook Pro 13" Touch Bar Replacement, Disconnect wifi and Bluetooth antennas: 步骤 23 中的图像 1,1
    • Disconnect the cables carefully with a plastic pry tool.
    • Be gentle, if too much force is applied it can take the board connector up with it.
  24. 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar cable 1: 步骤 24 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar cable 1: 步骤 24 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar cable 1: 步骤 24 中的图像 3,3
    • Remove the metal shield carefully.
    • Carefully unplug the connector.
  25. 2018 MacBook Pro 13" Touch Bar Replacement, Right speaker cable: 步骤 25 中的图像 1,1
  26. 2018 MacBook Pro 13" Touch Bar Replacement, ZIF connector: 步骤 26 中的图像 1,1
  27. 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Right Thunderbolt ports: 步骤 27 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Unplug Right Thunderbolt ports: 步骤 27 中的图像 2,2
  28. 2018 MacBook Pro 13" Touch Bar Replacement, Touch bar bracket / Flex: 步骤 28 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch bar bracket / Flex: 步骤 28 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch bar bracket / Flex: 步骤 28 中的图像 3,3
    • Use a T4 Torx driver to remove the screw.
    • T4 Torx screw.
  29. 2018 MacBook Pro 13" Touch Bar Replacement, Audio socket / Touch ID bracket: 步骤 29 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Audio socket / Touch ID bracket: 步骤 29 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
    • Remove the bracket.
  30. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 30 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 30 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 30 中的图像 3,3
    • gently disconnect the audio socket flex cable with a spudger.
    • gently disconnect the Touch ID flex cable with a spudger.
  31. 2018 MacBook Pro 13" Touch Bar Replacement, Display cable: 步骤 31 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Display cable: 步骤 31 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Display cable: 步骤 31 中的图像 3,3
    • Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
    • Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
    • gently disconnect the flex cable with a spudger.
  32. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 32 中的图像 1,1
    • Use a T5 Torx driver to remove the six 2.2mm screws securing the logic board.
    • Use a T3 Torx driver to remove the three 1.9mm screws securing the logic board.
    • Use a T5 Torx driver to remove the two 2.3mm (3.7mm head) screws securing the heatsink.
  33. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 33 中的图像 1,1
    • Carefully lift up the logic board, make sure none of the connectors are connected, also make sure they aren't caught on the logic board.
  34. 2018 MacBook Pro 13" Touch Bar Replacement: 步骤 34 中的图像 1,1
    • Congratulations you have now removed your MacBook's LogicBoard
  35. 2018 MacBook Pro 13" Touch Bar Replacement, Prepare for the next steps: Identify the Touch Bar connectors: 步骤 35 中的图像 1,1
    • In red you can see the two connectors for the Touch Bar. We will need to remove other parts first to be able to free them and be able to install the new connectors.
    • In green one notable screw that you need to remove because the board it holds in place prevents the Touch Bar connectors from exiting/entering through the main case of the MacBook.
    • We will therefore need to unplug both connectors, and remove the board, which takes a few additional steps that follow below.
  36. 2018 MacBook Pro 13" Touch Bar Replacement, Second Touch Bar connector: 步骤 36 中的图像 1,1
    • Carefully unplug the second Touch Bar connector
  37. 2018 MacBook Pro 13" Touch Bar Replacement, Touch ID sensor: 步骤 37 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch ID sensor: 步骤 37 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch ID sensor: 步骤 37 中的图像 3,3
    • This is not strictly required. However I found when removing the Touch Bar that it necessitated a lot of scraping and force near the Touch ID sensor, thus I advise removing it for protection.
    • It is quite easy to remove, just be careful with the flex cable as it seems very fragile.
    • Remove the 4 red screws
    • Remove the 2 green screws
    • Remove the black bracket which is now free
    • Carefully open the laptop lid with the screen at the bottom. The Touch ID sensor should free itself and stay on the screen.
  38. 2018 MacBook Pro 13" Touch Bar Replacement, Loosen the screen hinge near the Touch Bar connectors: 步骤 38 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Loosen the screen hinge near the Touch Bar connectors: 步骤 38 中的图像 2,2
    • This is necessary in order to remove the Touch Bar board and screw
    • Loosen the 3 T8 screws of the screen hinge
    • Be careful not to completely remove those screws
    • Be careful to be very gentle with the hinge from then on not to exert too much force on the cables going through the hinge axis !
  39. 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar board: 步骤 39 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar board: 步骤 39 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar board: 步骤 39 中的图像 3,3
    • Remove the red screw half hidden between the screen hinge (I already removed it in the picture)
    • This screw is smaller than T3 but I used a knife tip because I didn't have such a small screwdriver.
    • Then remove the Touch Bar board and its flex cable, they have some adhesive so be careful. The Touch Bar connectors are now freed to pass through and out of the main case !
  40. 2018 MacBook Pro 13" Touch Bar Replacement, Start removing the Touch Bar: 步骤 40 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Start removing the Touch Bar: 步骤 40 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Start removing the Touch Bar: 步骤 40 中的图像 3,3
    • Thanks to the removal of the Touch ID sensor, we have some room to get under the Touch Bar to remove it.
    • Seeing how messy the next steps got for my, I adise taping over the bottom of the screen and top of the keyboard to prevent any dirt bits getting stuck there. I put some tin foil over the rest of the keyboard but a paper or plastic sheet would be better.
    • I used a flathead screw driver but at first only the top glass popped off.
    • In the end I tried using an adhesive dissolver fluid, some thin spudgers, some fishing wire, but only brute force and the flat head screwdriver really solved it.
    • Please wear gloves and glasses as there are many glass shards flying about.
    • Keep scraping slowly but with force. This part took me about an hour.
  41. 2018 MacBook Pro 13" Touch Bar Replacement, Have patience and keep on going: 步骤 41 中的图像 1,3 2018 MacBook Pro 13" Touch Bar Replacement, Have patience and keep on going: 步骤 41 中的图像 2,3 2018 MacBook Pro 13" Touch Bar Replacement, Have patience and keep on going: 步骤 41 中的图像 3,3
    • After finally removing the brunt of the Touch Bar material, I could remove the connectors going through the main body.
    • I spent some time scraping the remainders and the glue with different tools. Using a knife worked best, while being careful not to get injured or damage the screen.
    • The Touch Bar slot was somewhat scratched but in the end it didn't matter after installing a new Touch Bar.
  42. 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar connector hole: 步骤 42 中的图像 1,2 2018 MacBook Pro 13" Touch Bar Replacement, Touch Bar connector hole: 步骤 42 中的图像 2,2
    • When completely removed, the Touch Bar connector body passthrough is clearly visible from the top and bottom.
    • Contrats, you have removed your Touch Bar !
结论
Now put in your new Touch Bar, make sure when installing it that the Touch ID sensor still fits. You can reinstall the Touch ID sensor first, so the Touch Bar is better aligned when you adhere it.
Make sure it is well adhered in its slot, then follow the instructions in reverse order to reassemble the rest of the laptop !
另外一个人完成了本指南。
Shldnet
于04/14/23注册
190 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 45
总计 208
