跳转到主内容
2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement
你所需要的
  1. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: 步骤 1 中的图像 1,2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: 步骤 1 中的图像 2,2
    • Pop the hood and remove the plastic battery cover.
  2. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 2 中的图像 1,1
    • Using a 1/4 inch flex head ratchet and a 1/4 inch shallow 10mm socket, loosen the battery cable tightening nut.
  3. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 3 中的图像 1,1
    • Remove the vacuum line from the front of the intake by gently pulling up on the line releasing it from the clamps.
  4. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 4 中的图像 1,1
    • Disconnect the MAP sensor.
  5. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 5 中的图像 1,2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 5 中的图像 2,2
    • Using a 1/4 inch 7mm deep socket and 1/4 inch flex head wrench, loosen the worm clamp on the cold air intercooler pipe.
  6. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 6 中的图像 1,2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 6 中的图像 2,2
    • Using a 1/4 inch 10mm wobbly socket, 1/4 inch 8 inch extension, and 1/4 inch ratchet, remove all 5 of the cap screws holding the intake to the cylinder head.
  7. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 7 中的图像 1,1
    • Remove the intake out of the engine bay by lifting and pulling the intake towards you.
  8. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 8 中的图像 1,2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 8 中的图像 2,2
    • Unplug both left and right engine ground strap connections.
  9. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 9 中的图像 1,1
    • Using a 1/4 inch 8mm deep socket, remove the 8 PCV plate mounting bolts.
  10. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 10 中的图像 1,1
    • Remove the PCV plate and the old PCV plate gasket.
  11. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 11 中的图像 1,1
    • Wipe down the mounting surface and the inside of the PCV plate with a shop rag.
  12. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 12 中的图像 1,1
    • Install the new PCV plate gasket.
  13. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 13 中的图像 1,2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: 步骤 13 中的图像 2,2
    • Reinstall the PCV plate on the side of the engine block.
    • Torque the PCV plate mounting bolts to 89 inch pounds.
结论
4等其他人完成本指南。
2条评论
Can this be the p04DB code that came up on my car??
Angelo - 回复
Would this fix the code p04DB
Angelo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 192
总计 5,021
