跳转到主内容
2018 Chevrolet Equinox Cabin Air Filter Replacement
你所需要的
  1. 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,2 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,2
    • Turn off vehicle air.
    • Find the glove box on the passenger side of the vehicle.
    • Open and remove all items from the glove box.
  2. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 2 中的图像 1,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 2 中的图像 2,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 2 中的图像 3,3
    • You will see a latch on the right side of the glove box.
    • Unhook the latch by gently pulling the latch outwards from the glove box.
  3. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 3 中的图像 1,2 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 3 中的图像 2,2
    • Place your hands on the sides of the glove box.
    • Tightly squeeze the sides inward, and pull the glove box forward to detach the glove box from the dashboard.
  4. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 4 中的图像 1,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 4 中的图像 2,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 4 中的图像 3,3
    • The cabin air filter box has one 7/32" screw on each side.
    • Use a 7/32" nut driver to remove these two screws.
  5. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 5 中的图像 1,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 5 中的图像 2,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 5 中的图像 3,3
    • Plastic tabs will be right beneath the screws highlighted by markups.
    • Push the tabs in on both sides of the box simultaneously.
    • Lift the lid of the box to find the old cabin air filter.
  6. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 6 中的图像 1,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 6 中的图像 2,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 6 中的图像 3,3
    • Remove the filter, and check for debris in the filter box.
  7. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 7 中的图像 1,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 7 中的图像 2,3 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 7 中的图像 3,3
    • Place the new filter in the filter box.
    • The filter has an arrow, as indicated by the red box. Ensure that the arrow points down when placing the filter.
  8. 2018 Chevrolet Equinox Cabin Air Filter Replacement: 步骤 8 中的图像 1,1
    • Pull the lid down and press both sides to close the filter box.
    • If you hear a clicking sound, then it means that the lid is closed.
结论
To reassemble your glovebox, follow these instructions in reverse order.
Allan
于06/08/22注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 119
总计 2,691
