简介
使用本指南可以借助iFixit电池更换套装从 MacBook Pro 中安全地取出内置电池。 套装中的粘合剂去除剂将溶解固定电池的粘合剂,使你可以轻松地将其移除。
“iFixit粘合剂去除剂是高度易燃的。''请'在通风良好的地方进行此项操作。 在这个过程中不要在明火附近抽烟或工作。
为了降低损坏危险,在开始此指南之前,请先将MacBook Pro的电池电量耗尽。如果意外刺破,带电的锂离子电池可能会造成危险且无法控制的火灾。如果你的电池已经鼓包,请参考此指南
注意:用于溶解电池粘合剂的溶剂会在你的扬声器与塑料扬声器音箱接触时损坏。 本指南指导你在继续使用电池之前取下扬声器。
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
在相反的一侧重复上一个步骤,在底壳下方滑动你的三角撬片,然后在一侧向上滑动以弹出第二个夹子。
Recommend being very careful on this step and the following step when using any opening tool to always keep the “pointy end” up when prying, especially about 40mm up the side, to avoid completely destroying the speaker diaphragms.
将底壳牢固地拉向MacBook的正面(远离铰链区域),以分离固定下壳体的最后一个夹子。
首先在一个角落拉,然后在另一个角落拉。
使用一个撬棒的尖端翻转小的黑色锁定标签,以确保电缆在其接口。
Be very careful here. It is easy to break the whole connector off the battery board, which is what I did. Luckily the connector is part of the replacement battery, so you just need to remove the connector from the cable. The pictures here should provide more detail so you can see better what is going on.
thanks a lot !!!!! great help :)
将电池板数据线从插座中滑出,断开。
沿着电缆的方向平行于主板滑动。
As simple as this step might seem, the golden leads will disapper the moment you remove it as it has some adhesive under the black strip that covers it. Ensure you peel it back enough to display the golden leads after swapping the batteries out.
Your battery may come with this ribbon cable. In that case, disconnect the other end.
将电池板数据线折叠到一边,不要挡道。
轻轻地断开电池接口,用小撬棒轻轻地拔出电池。
将接口抬得足够高,使其与插座保持分离。如果在维修过程中意外接触,可能会损坏MacBook Pro。
To completely avoid accidental contacts I recommend to wrap this connector in a piece of paper and hold it in place with tape.
Do not put tape directly on the contact underside, as that may leave some glue that would affect the contact conductivity.
I put a piece of tape on the underside of the connector (sticky side up) to insure against accidental battery contact. If you put tape on the logic board side of the connection, some insulating padding material might accidentally stick to the tape when the tape is removed during reassembly.
使用T3 Torx 螺丝刀拆下两个1.8 mm 螺丝固定轨迹板电缆接口支架。
用一个撬棒将触控板的连接线从主板上直接撬开,从而断开触控板的色带线。
准备一个 iOpener 并把它放在触控板带电缆的顶部大约一分钟,以软化粘合剂固定触控板带电缆到电池顶部。
如果你没有iOpener,用吹风机加热电缆代替。电缆应该是温暖的,但不要太热触摸。小心不要使电池过热。
小心地将触控板带线从电池上剥离,并将其推到一边。
使用T5 Torx 螺丝刀拆下十颗固定触控板总成的螺丝:
两个4.3 mm 螺丝
八个5.8 mm 螺丝
Heating the wrist-pad area and carefully using a plastic card to separate the adhesive allowed me to remove the battery without needing to use the solvent or removing the track-pad. No need for taping the speakers.
I attempted as well the shortcut with no solvent and no track-pad removal. Also, I didn't apply heating. Everything was totally fine yet a bit risky. In such conditions it is very hard not using the spudger flat tip to lift the battery packs. Well, I highly recommend NOT using the spudger on the two central packs. In fact, it would be extremely easy to destroy surface mounted components on the track-pad board which would be accessible through the metal frame holes under the packs (see pics along this guide). Plastic cards are always fine. Next time, I would probably avoid spudger and introduce floss as shown in Picture 34 below.
bc_ -
移除触控板组件。
确保不要丢失位于触控板底部的六个小垫圈(两个圆形和四个长方形)。
Should include instruction to wedge thin paper one every side of the trackpad to keep it aligned during reinstallation. Without the wedges, the trackpad would come out misaligned, which might damage it from excessive friction. Kapton tape might also work, didn't try it though.
These instructions were standard for Unibody models in the past, don't know why it wasn't included here.
为了保护你的显示器,请在显示器和键盘之间放置一块铝箔,并在工作时将其留在那儿。
此外,使用一些胶带和/或箔纸密封触控板下方的区域。你也可以选择在触控板区域的正下方铺一层吸水毛巾,以吸收多余的去粘剂。
This is an important point. I had missed. I feel a better image with a towel would better emphasize.
用撬棒沿胶带的边缘按一下,将其牢固地粘贴到 MacBook Pro 的铝制外壳上,将扬声器与电池隔离开。
折叠胶带,然后轻轻将其粘贴到扬声器上,以免干扰。
The speaker membrane is also relatively delicate. You can put a small piece of paper to protect it, to avoid the tape gluing to it directly.
现在,你的MacBook Pro已做好充分准备,现在该做好准备了。
在处理和应用脱胶剂时,请戴上护目镜。(您的套装中包括眼睛保护装置。)
不要戴上没有护目镜的隐形眼镜。套装中还包括防护手套。
如果你担心可能会引起皮肤刺激,请戴上手套。
从胶水去除剂瓶中拉出黑色橡胶塞。
用剪刀剪下密封尖端。
靠近狭窄的尖端进行切割将为你提供更好的控制,因此你可以少量使用胶水去除剂。
几分钟后,从前边缘开始,将塑料卡的一个角插入最右边的电池下面。
左右摆动存储卡,并将其一直滑到电池下方。
提起以完全分离粘合剂,但请勿尝试卸下电池。
将塑料卡暂时留在电池下面,以防止在继续操作时重新粘附。
在剩余的三个电池单元中的每一个下面都涂几滴粘合剂去除剂。
注意泄漏,如果需要,请在以下步骤中使用更多的胶水去除剂。
等待约两分钟,然后再继续。
取出电池。
在安装新电池之前,请从MacBook Pro的外壳中清除所有残留的粘合剂。
用镊子或戴手套的手指将所有大条胶粘剂剥离。
用塑料工具刮掉所有残留的粘合剂块,然后用除胶剂或异丙醇清洁下面的区域。沿一个方向擦拭(不要来回擦拭),直到清洁机箱并准备好装入新电池为止。
完成后,小心地从扬声器上取下保护带。
请注意电池数据线,并确保它不会被夹在电池板上。
如果你的电池底部预装有胶粘剂,请将其翻转过来并小心地剥离内衬以露出胶粘剂。如果电池没有粘合剂,请使用薄的双面胶带(例如Tesa 61395)将电池固定到位。
小心放置电池并将其放置到位。
牢牢按住每个电池单元格5-10秒钟,以将其固定到底部外壳。
Extremely detailed and easy to follow instructions! I ordered all the tools from ifixit and they worked great. I didn’t use the adhesive remover. I was able to carefully work a plastic card behind each battery section. This took a little more effort but I didn’t feel comfortable using acetone on a macbook.
Instead of acetone/alcohol blend adhesive remover I used 91% isopropyl alcohol available at any pharmacy. Acetone will melt many/most plastics, alcohol will not.
91% isopropyl alcohol and a thin plastic card worked fine, took a little more time and patience but worked.
While the acetone is better at loosening/removing adhesive, you also increase the risk of damaging plastics around the battery area or worse if it should leak into the keyboard or other area!
As the instructions note ... DO NOT over apply their adhesive remover!
Thanks iFixit for providing great tutorials, parts and supplies!
Happy Customer
33等其他人完成本指南。
由衷感谢以下译者:
95%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
15条评论
When remounting, putting back the trackpad in a nicely centered position can become a lengthy exercise of patience.
I haven’t find guides or tricks to help; the best I came up with was to
* put back just two corner screws, without tightening them, that is enough to keep it in place and not lose the washers
* flip back your macbook keyboard up
* center the trackpad and fix it in place with adhesive tape
* flip it back belly-up, tighten the two corner screws and add the remaining six.
Thanks; everything went well, except at the end I realized that I somehow damaged the battery connector from step 12/13. What is the part number, please?
Der Akkutausch funktioniert auch mit dem Heißluftfön bei max. 100° Celsius…
Einfach die Akku-Sektionen dazu eine Minute etwas erwärmen und dann mit der Karte den Klebstoff lösen!
Der Einbau des Trackpads ist etwas fummelig da es beim Zentrieren keine Arretierung oder ähnliches gibt, dazu am besten einige Schrauben etwas anziehen und dann systematisch festziehen! Ich legte das aufgeklappte MacBook über einen Überhang damit ich von oben das Trackpad immer justieren konnte und mit der anderen Hand schraubte ich von unten die Schrauben fest ;-)
I fixed it! My original battery had swollen badly and had been a fire hazard.
This was my first time fixing a phone / laptop. Instructions were quite clear and easy to follow. I didn't run into any problem.
Very proud of myself at the moment ☺️
Is it possible to remove the battery with heat rather and remover?
After completing this repair, my space bar feels slightly sticky and no longer registers presses, unless they are firm and in the very middle of the key. I think it's very important to let all of the solvent thoroughly dry out while the laptop is still open and before the new battery is installed, or some of the vapors may penetrate the keyboard and result in gunk getting deposited under the key dome, causing this issue. I'm not sure how to resolve this without removing and attempting to disassemble the entire keyboard, which is difficult on this model.
Excellent descriptions and photos. I did this without incident.
Happy Customer
How long does your laptop run with battery you placed without connecting power source ? I mean the how is the battery performance? Did you buy from Ifixing ?
Thank you so much Tarun.
Great!!!
Muchas gracias Tarun.
The cable referenced in steps 11 through 13 was different than what was shipped. The battery pack I received had that cable glued in place on the battery side. I. disconnected the original cable from the motherboard and used the cable that was included (attached) to the replacement battery, connecting it on the terminal that the original was attached to. I'm not sure where the difference came from, I am charging the battery as I write this and hope that it charges correctly. I know it boots up, I did that and put the Auto Boot setting back to original.
Super Anleitung, hat alles wie beschrieben funktioniert und mit dem Tool Kit für den Batterie Wechsel waren alle benötigten Werkzeuge dabei. 10 von 10 Punkten !!! DANKE
MacBook Pro 13" Retina 2018
Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
Macrepair SF - 回复
@mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
Jeff Suovanen -
Thats right! You don't want power running while working on your logic board.
Dan -
This did not work when running High Sierra.
Kyle B - 回复
Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
Cool_Breeze - 回复
I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
Brian - 回复
Is this step necessary if my mac can turn on? Battery fully dead(
Nursat b - 回复
BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
Jason Sherron - 回复
This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
Patrick Machacek - 回复
Not able to do that with damaged screen
richardjgreen - 回复
If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
Roberto Sanchez Bustos -
Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
Adrian Vizik - 回复
Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
Roberto Enrieu - 回复
running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
result: `AutoBoot %00`
Marek Polák - 回复
Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's:
nvram -p | grep 'auto-boot'
to display the current state, the default istrue
- and then to change it,sudo nvram auto-boot=false
which turns it off.Ed Mechem -
This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
Grant Ormsby - 回复
It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
tommy404 - 回复
I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
hatuxka - 回复
BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
bcardanha - 回复
I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
peter sussex -
When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
johann beda - 回复
When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a
pwd
(print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.Ed Mechem -
I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
Mircea Comanici - 回复
After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
Ed Mease - 回复
This should be the default. IMO I tell you to power on - not the lid.
G Sena - 回复
Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
maël muzelet - 回复
Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
Claire Miesch -
Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
Tom Markham - 回复
If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
arichard2401 - 回复
For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
Nicholas R Licato - 回复
Just replaced my 2018 15" MBP battery. Running Sonoma.
I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
Cédric Bontems - 回复
After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
Now, after replacement of the battery, this is all I get to see.
No reset of NVRAM nor PRAM helped.
Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
webrockers - 回复
I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
I missed connecting the left TouchID sensor from step 31.
webrockers -
