跳转到主内容
2017 Toyota 4Runner Key Fob Battery Replacement
你所需要的
  1. 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 3,3
    • Push the side button on the key fob to release the real key from the fob.
  2. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 2 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 2 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 2 中的图像 3,3
    • Insert the key into the same shaped slit at the bottom of the key fob.
    • Twist the key to the right.
    • Separate the two halves of the key fob.
  3. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 3 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 3 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the circuit board from the inside of the fob.
  4. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 4 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 4 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the battery gently with a nylon spudger.
    • Make sure you don't damage any of the three tabs that hold the battery in place.
  5. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 5 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 5 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 5 中的图像 3,3
    • Place a new battery gently back into the circuit board with the positive side of the battery facing up.
    • Make sure the tabs click into place.
  6. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 6 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 6 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 6 中的图像 3,3
    • Align the circuit board with the base of the fob case and gently press it back into place.
  7. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 7 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 7 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 7 中的图像 3,3
    • Align the top and base of the fob and snap it back into place.
  8. 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 8 中的图像 1,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 8 中的图像 2,3 2017 Toyota 4Runner Key Fob Battery Replacement: 步骤 8 中的图像 3,3
    • Insert the key back into the fob.
终点
另外一个人完成了本指南。
Nic
于01/18/22注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 80
总计 2,250
