跳转到主内容
2017 Jeep Cherokee Air Filter Replacement
你所需要的
  1. 2017 Jeep Cherokee Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,2 2017 Jeep Cherokee Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,2
    • Pull thehood release lever on the driver's side, under the dashboard until you hear the hood pop open slightly.
    • The hood release is typically marked with a car icon.
    • Walk to the front of the vehicle and reach under the hood to find the secondary safety latch. Slide or lift this latch to fully release the hood.
    • Carefully lift the hood.
  2. 2017 Jeep Cherokee Air Filter Replacement: 步骤 2 中的图像 1,2 2017 Jeep Cherokee Air Filter Replacement: 步骤 2 中的图像 2,2
    • The engine air filter housing is a rectangular, black plastic box situated near the front left of the engine bay (if you are facing the engine bay).
  3. 2017 Jeep Cherokee Air Filter Replacement: 步骤 3 中的图像 1,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 3 中的图像 2,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 3 中的图像 3,3
    • Ensure the engine has cooled down to avoid the risk of burns.
    • Use a Phillips #2 screwdriver to remove the three 8 mm screws securing the air filter housing cover.
    • There are two screws located at the front of the housing and one at the back.
    • Carefully set each screw aside in a safe spot to prevent them from rolling away or getting lost.
  4. 2017 Jeep Cherokee Air Filter Replacement: 步骤 4 中的图像 1,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 4 中的图像 2,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 4 中的图像 3,3
    • Lift the cover off the air filter housing.
    • Observe how the old air filter sits inside the housing to ensure correct orientation when installing the new filter.
    • Remove the old air filter by lifting it straight out of the housing.
    • Inspect it for excessive dirt and debris to determine the filter's condition.
    • Handle the old filter carefully to avoid dispersing accumulated dirt.
  5. 2017 Jeep Cherokee Air Filter Replacement: 步骤 5 中的图像 1,1
    • Place the new filter into the housing, making sure it is properly oriented.
    • The filter should fit snugly without any gaps around the edges.
    • Double-check the orientation and fit of the new filter to ensure proper airflow.
  6. 2017 Jeep Cherokee Air Filter Replacement: 步骤 6 中的图像 1,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 6 中的图像 2,3 2017 Jeep Cherokee Air Filter Replacement: 步骤 6 中的图像 3,3
    • Place the cover back on the air filter housing.
    • Replace the three 8 mm screws and secure them with the Phillips #2 screwdriver.
    • Ensure all screws are accounted for and tightly fastened to avoid vibrations or unfiltered air entering the engine.
结论
Replacing the air filter in your 2017 Jeep Cherokee is a simple and essential maintenance task that helps ensure optimal engine performance and efficiency. By following the step-by-step guide to unfasten the housing, remove the old filter, and install a new one, you can effectively maintain your vehicle's air intake system.
Joseph Howerton
于03/05/24注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-8, Grodsky Spring 2024 CSU Los Angeles, Team 7-8, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 59
