跳转到主内容
2016 Nissan Altima Key Fob Battery Replacement
你所需要的
  1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: 步骤 1 中的图像 1,3 2016 Nissan Altima Key Fob Battery Replacement, Battery: 步骤 1 中的图像 2,3 2016 Nissan Altima Key Fob Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
  2. 2016 Nissan Altima Key Fob Battery Replacement: 步骤 2 中的图像 1,1
    • Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
    • Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
  3. 2016 Nissan Altima Key Fob Battery Replacement: 步骤 3 中的图像 1,1
    • Pry out the battery with a flathead to avoid skin contact with electrical components.
    • Make sure to avoid touching the motherboard.
  4. 2016 Nissan Altima Key Fob Battery Replacement: 步骤 4 中的图像 1,1
    • Now carefully place the new battery onto the silver platter.
    • Keep in mind positive side of the battery will be facing downward, while negative side will be facing towards you.
  5. 2016 Nissan Altima Key Fob Battery Replacement: 步骤 5 中的图像 1,1
    • Line up the parts in order to secure the key.
    • Press down until the case makes a "click" sound.
  6. 2016 Nissan Altima Key Fob Battery Replacement: 步骤 6 中的图像 1,1
    • Finally, insert the physical key back into the fob to complete your replacement.
结论
另外一个人完成了本指南。
Giovanni Avalos
于12/06/22注册
160 声望
撰写一个指南
团队
CSU Los Angeles, Team G-11, Briggs Fall 2022 CSU Los Angeles, Team G-11, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22SGG11
1 名成员
创作了1篇指南
一条评论
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
Erik - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 42
过去 30 天: 197
总计 3,725
