跳转到主内容
2016 Dodge Dart SXT LED Dome Lights Replacement
你所需要的
  1. 2016 Dodge Dart SXT LED Dome Lights Replacement, LED Dome Lights: 步骤 1 中的图像 1,3 2016 Dodge Dart SXT LED Dome Lights Replacement, LED Dome Lights: 步骤 1 中的图像 2,3 2016 Dodge Dart SXT LED Dome Lights Replacement, LED Dome Lights: 步骤 1 中的图像 3,3
    • Always be sure to properly disconnect the battery before doing any electrical work on the car.
    • Use a spudger to gently pry down on the clear plastic covers until they pop off.
    • Do not pry on or near the highlighted spaces in the pictures. These areas are where the clips are located and are much more prone to damage.
  2. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 2 中的图像 1,3 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 2 中的图像 2,3 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry off the silver reflective pieces within the socket housing.
    • Be cautious prying near the highlighted areas. However, for these inserts, the clips are less likely to break due to their location underneath.
  3. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 3 中的图像 1,1
    • Gently remove the old, burnt out bulbs from the electrical socket.
  4. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 4 中的图像 1,1
    • Adding a small amount of bulb grease to the connection can help prevent moisture build up and preserves the health of the socket.
    • Gently push the new bulbs into the sockets, making sure not to damage the embedded wire leads.
  5. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 5 中的图像 1,1
    • Replace the silver inserts and clear covers by pushing the clips back into their respective slots.
  6. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 6 中的图像 1,3 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 6 中的图像 2,3 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 6 中的图像 3,3
    • Repeat the process for the rear dome lights.
  7. 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 7 中的图像 1,2 2016 Dodge Dart SXT LED Dome Lights Replacement: 步骤 7 中的图像 2,2
    • Reconnect the car battery.
    • Test each light to ensure the bulbs are properly connected and light up by clicking each one on and off several times.
结论
The newly replaced dome lights should retain all prior functionality, turning on when a door is opened or by pressing on the cover itself.
Jason Houston
于09/15/20注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 570
