跳转到主内容
加入维修社区 - 创建账户
2016-2020 Honda Civic Battery Replacement
浏览量: 9314
浏览统计数据:
过去24小时
24
过去 7 天:
240
过去 30 天:
1,029
总计
9,314
评论: 1
1 comment on steps.
已完成: 4
4 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 10 - 20 分钟
难度: 中等
特色学生指南
该指南是我们优秀学生的辛勤劳动的成果,iFixit的工作人员认为这个很酷。
This guide will walk you through replacing the 12V battery in a 2016–2020 Honda Civic. This repair is essential when the battery no longer holds a charge or the car struggles to start.
Before you begin this repair, make sure that the car is off and parked on a flat surface. If you have driven recently, wait until the engine cools before you begin. Wear gloves and safety glasses to avoid injury.
Caution: When disconnecting the battery cables, always start with the negative terminal first, then disconnect the positive terminal. When reconnecting the cables, connect the positive terminal first, then the negative. This helps prevent accidental short circuits.
你所需要的
    1. 2016-2020 Honda Civic Battery Replacement, Battery: 步骤 1 中的图像 1,3 2016-2020 Honda Civic Battery Replacement, Battery: 步骤 1 中的图像 2,3 2016-2020 Honda Civic Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Open the driver's side door and look between the speaker and steering wheel.
      • Pull the lever with the icon showing a car with an open hood to release the hood.
      • Make your way to the front of your car.
      询问修复机器人
      添加评论
    2. 2016-2020 Honda Civic Battery Replacement: 步骤 2 中的图像 1,3 2016-2020 Honda Civic Battery Replacement: 步骤 2 中的图像 2,3 2016-2020 Honda Civic Battery Replacement: 步骤 2 中的图像 3,3
      • Insert your hand into the space under the hood slightly left of center, then slide it to the right.
      • With the lever compressed, pull the hood up with your other hand.
      • Lift the hood prop rod and slide the end into the hole in the roof of the hood.
      • Make sure that it is securely attached and holding the hood up before you let it go to avoid injury.
      询问修复机器人
      添加评论
    3. 2016-2020 Honda Civic Battery Replacement: 步骤 3 中的图像 1,3 2016-2020 Honda Civic Battery Replacement: 步骤 3 中的图像 2,3 2016-2020 Honda Civic Battery Replacement: 步骤 3 中的图像 3,3
      • With the socket wrench, loosen the nut on the negative (black) terminal of the battery.
      • It is important to remove the negative (black) contact first to minimize the risk of short-circuiting the battery.
      • Pull straight up on the cable connector after loosening it.
      询问修复机器人
      添加评论
    4. 2016-2020 Honda Civic Battery Replacement: 步骤 4 中的图像 1,3 2016-2020 Honda Civic Battery Replacement: 步骤 4 中的图像 2,3 2016-2020 Honda Civic Battery Replacement: 步骤 4 中的图像 3,3
      • Use a 10 mm wrench to loosen the nut on the positive (red) contact.
      • When loosened, pull straight up to remove the contact.
      询问修复机器人
      添加评论
    5. 2016-2020 Honda Civic Battery Replacement: 步骤 5 中的图像 1,3 2016-2020 Honda Civic Battery Replacement: 步骤 5 中的图像 2,3 2016-2020 Honda Civic Battery Replacement: 步骤 5 中的图像 3,3
      • Lift the battery out of the engine bay using the handle on top.
      • Place the new battery into the compartment with the negative terminal at the top (farthest from you) and the positive terminal at the bottom (closest to you) as you stand in front of the hood.
      • Make sure the new battery is orientated like the old one to ensure correct terminal connections.
      询问修复机器人
      添加评论
    6. 2016-2020 Honda Civic Battery Replacement: 步骤 6 中的图像 1,3 2016-2020 Honda Civic Battery Replacement: 步骤 6 中的图像 2,3 2016-2020 Honda Civic Battery Replacement: 步骤 6 中的图像 3,3
      • Rub the terminals of the new battery with sandpaper to remove any oxidation and ensure better electrical contact.
      • Sanding the terminals improves contact and prevents corrosion.
      • Slide the negative (black) cable onto the negative terminal and tighten the nut.
      • Slide the positive (red) cable onto the positive terminal and tighten the nut.
      添加评论
    7. 2016-2020 Honda Civic Battery Replacement: 步骤 7 中的图像 1,2 2016-2020 Honda Civic Battery Replacement: 步骤 7 中的图像 2,2
      • Hold the hood with one hand, remove the hood prop, and clip it back into place at the top of the engine bay.
      询问修复机器人
      添加评论
    8. 2016-2020 Honda Civic Battery Replacement: 步骤 8 中的图像 1,2 2016-2020 Honda Civic Battery Replacement: 步骤 8 中的图像 2,2
      • Close the hood by lowering it to a few inches above the latch, then let it drop into place.
      • Pressing down instead of dropping may prevent it from closing properly.
      询问修复机器人
      添加评论
    9. 2016-2020 Honda Civic Battery Replacement: 步骤 9 中的图像 1,1
      • Get into your car and start it to ensure the new battery works properly.
      • You may see warning lights for systems such as the lane departure, collision mitigation, or radio code entry. These should disappear after 5–10 minutes of driving or a manual reset depending on the system.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
Shawn Hoang
于04/07/25注册
211 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-5, Ribeiro Spring 2025 CSU Los Angeles, Team 2-5, Ribeiro Spring 2025 的会员
CSULA-RIBEIRO-S25S2G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 240
过去 30 天: 1,029
总计 9,314
