跳转到主内容
加入维修社区 - 创建账户
2016-2021 Honda Civic Headlight Bulb Replacement
你所需要的
  1. 2016-2021 Honda Civic Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
  2. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 2 中的图像 1,1
    • Locate the headlight.
  3. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 3 中的图像 1,3 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 3 中的图像 2,3 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 3 中的图像 3,3
    • Unplug the connector by pushing down on the top of the tab shown and pull it apart.
    • It should disconnect easily. If there is any resistance than you need to press the tab harder.
  4. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 4 中的图像 1,2 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 4 中的图像 2,2
    • Twist the bulb counterclockwise and pull bulb out.
  5. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Align the three tabs on the new bulb to the three spaces in the housing for the headlight bulb.
  6. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Insert the new bulb and twist clockwise until it clicks.
    • Avoid touching the bulb with your hands as the oil on your hands can be damaging and cause the bulb to fail prematurely.
  7. 2016-2021 Honda Civic Headlight Bulb Replacement: 步骤 7 中的图像 1,1
    • Reconnect wires to the new bulb.
结论
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
5等其他人完成本指南。
团队
3指南评论
Can you post a link of where to buy the exact same new lightbulb? Thanks
AnnaSmith - 回复 分享
Hi @annasmith55441, the link to the bulb listed at the top of the guide under parts is the correct type for a 2016-2021 Honda Civic. There are a couple of links to choose from depending on the features you need from the bulb. If you're concerned that these bulbs won't work for your car, Amazon has a feature to check the compatibility of the bulbs with your specific car make and model at the top of bulb page link. I hope this helps!
Sarah Westberg - 分享
Headlight replace
Doug - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 122
过去 30 天: 639
总计 30,266
