跳转到主内容
2016-2021 Chevrolet Camaro Brake Light Bulb Replacement
你所需要的
  1. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement, Brake/reverse light bulb: 步骤 1 中的图像 1,2 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement, Brake/reverse light bulb: 步骤 1 中的图像 2,2
    • Using either the button on your vehicle's key fob, or the button on the driver's side door, open the trunk.
    • ​ Go to the rear of the vehicle and lift the rear trunk lid until it reaches its highest position and locks out.​
  2. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 2 中的图像 1,3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 2 中的图像 2,3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, gently pry the covers for the pop-rivets out.
    • Remove the pop-rivets themselves by inserting a spudger underneath them and prying up.​
    • There will be a gap for the head of the spudger on each pop-rivet.
  3. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 3 中的图像 1,1
    • After the fastener caps have been removed, twist the knob on top of the cover counterclockwise to remove it.
  4. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 4 中的图像 1,1
    • With the housing assembly open, gently lift the housing cover from the taillight assembly and set it aside.​ ​
  5. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 5 中的图像 1,3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 5 中的图像 2,3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 5 中的图像 3,3
    • Locate the reverse bulb socket; it will be identifiable by a wire running from the back of the tail light.
    • Gently grab the reverse bulb socket with your pliers, then gently turn it counterclockwise for one-quarter of a rotation.
  6. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: 步骤 6 中的图像 1,1
    • Pull the socket out from the assembly, and pull out the old bulb.
    • Insert your new bulb by gently pressing it into the socket.
    • Handle the bulbs very carefully, using a glove so that grease from your hands does not get onto the glass, thus reducing their useful life. Glass can break very easily and cause accidents.
结论
另外一个人完成了本指南。
一条评论
does not work for 2019 break lights
Emeterio Rivas - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 99
总计 3,182
