跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换
你所需要的
  1. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 禁用自动重启: 步骤 1 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 禁用自动重启: 步骤 1 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 禁用自动重启: 步骤 1 中的图像 3,3
    • 在开始此步骤之前,你必须禁用 Mac 的自动重启功能。自动重启功能会让 MacBook 在掀开盖子时自动开机。这个功能在拆卸过程中也可能会被意外触发。使用本指南或按照下面的简要说明来禁用自动启动。这项指令可能并不适用于所有 Mac。
    • 开机,并打开终端
    • 将以下命令复制粘贴到(或完全键入)终端窗口中:
    • sudo nvram AutoBoot=%00
    • [回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return
    • 你现在可以安全地关闭Mac电脑,并打开底壳,它不会再意外启动了。
    • 当修理完成、成功组装复原Mac电脑后,在「终端」中使用以下命令来启用「自动启动」功能:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - 回复
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - 回复
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - 回复
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - 回复
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - 回复
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - 回复
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - 回复
    Not able to do that with damaged screen
    richardjgreen - 回复
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - 回复
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - 回复
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - 回复
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - 回复
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - 回复
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - 回复
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - 回复
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - 回复
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - 回复
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - 回复
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - 回复
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - 回复
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - 回复
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - 回复
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - 回复
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - 回复
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - 回复
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除五角螺丝: 步骤 2 中的图像 1,1
    • 在继续之前,请拔下并关闭MacBook电源。关闭显示屏并将其放在柔软的表面上,顶部朝下。
    • 使用P5 五角螺丝刀卸下固定下壳的六个螺钉:
    • 两个6.2 mm 螺丝
    • 四个3.4 mm 螺丝
    • 在整个维修过程中,记录每个螺钉并确保它准确地回到原来的位置以避免损坏你的设备。
    Sur le mien A1708 EMC3164 j’ai 4 vis de 6,2 (les coins) et 2 vis de 3,4 celles au milieu en bas
    Olivier Cecillon - 回复
    Ce tutoriel n’est pas dans la bonne section !
    c’est le 13” avec touch bar et non celui avec les touches de fonction .
    l’autre tuto nommé “écran complet” est le bon
    Vincent Morault - 回复
    Bonjour Vincent,
    Si vous cherchez le même tutoriel pour le MacBook 13” non Touch Bar, le voici : https://fr.ifixit.com/Tutoriel/Remplacem...
    Claire Miesch -
    Before you start I suggest you get magnifier eyeware as screws and connectors are very small and good lightning are a big PLUS
    Gilles Vigeral - 回复
    Completed whole steps in over 4 hours….but worth it. Works back perfect and battery error message is gone….
    Gilles Vigeral - 回复
    Nothing beats a properly grounded ESD workstation, and a grounded wrist strap.
    Robin Ray - 回复
  3. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 用吸盘打开一个空隙: 步骤 3 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 用吸盘打开一个空隙: 步骤 3 中的图像 2,2
    • 在MacBook Pro前中心区域附近的下壳上使用吸盘。
    • 抬起吸气手柄,使下壳与底盘之间略微分离。
  4. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 分离夹扣: 步骤 4 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 分离夹扣: 步骤 4 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 分离夹扣: 步骤 4 中的图像 3,3
    • 将三角撬片的一角插入下壳和底盘之间的空间。
    • 将三角撬片绕最近的角落滑动,并在箱子侧面的一半处滑动。
    • 这将打开第一个将下壳固定到机箱的隐藏夹子。你应该感受并听到咔哒一声弹出。
    The instruction implies that sliding the pick up to the side of the case releases the clip. This is far from the truth; it takes a pretty strong force to pop the clip open. The plastic pick is a good start, but you need to reach in and pull the middle of that side of the case pretty hard.
    dkraemer2 - 回复
  5. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 5 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 5 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 5 中的图像 3,3
    • 在相反的一侧重复上一步,在下壳下方向上滑动三角撬片,向上滑动打开第二个夹扣。
  6. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 6 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 6 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 6 中的图像 3,3
    • 在下壳体的前边缘下方,在两个最中心的螺孔中的一个附近插入三角撬片。
    • 选择一个扭动角度,弹出第三个夹扣。
    • 在两个最中心的螺丝孔附近重复此过程,释放第四个夹扣。
    Look at Step 8 pics 2 and 3 to see exactly where the clips are that need to be released. Taking the bottom cover off my MBP took for ever because I didn’t realize the clips were not right around the edges as the wording suggests. Once I realized this, it came off quickly and easily.
    Troy Reimche - 回复
  7. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 7 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 7 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 7 中的图像 3,3
    • 将下壳牢固地拉向MacBook的上壳(远离链接区域),以分离固定下壳的最后一个夹子。
    • 首先拉动一个角落,然后另一个角落可能有帮助。
    • 往旁边拉动,而不是上面。
    • 这可能需要很大的力气。
    On the 2018 model, there are two more clips that need to be popped on the sides in the middle. Then it slides out easily.
    Cool_Breeze - 回复
  8. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除底壳: 步骤 8 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除底壳: 步骤 8 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除底壳: 步骤 8 中的图像 3,3
    • 移除底壳。
    • 要重新安装底壳:
    • 轻轻放置后盖并对齐靠近屏幕折叠铰链附近的滑动夹子铰链。向下按压并向屏幕折叠铰链方向滑动盖子。夹子接合后滑不动为止。
    • 当滑动夹完全啮合并且后盖看起来正确对齐时,牢牢地按下后盖以接合下面的四个隐藏的夹子。你应该能感觉到并听到它们迅速到位的声音。
  9. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 揭开电池接口的盖子: 步骤 9 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 揭开电池接口的盖子: 步骤 9 中的图像 2,2
    • 小心地剥掉覆盖在电池接口上的一大块胶带,它位于离电池最近的逻辑板边缘。
    • 移除胶布。
    Please be VERY careful, I torn up my battery cable and had to replace all the battery.
    Emmanuel Neff - 回复
    Apple worked on my computer and did not put the tape back. I'm assuming it's not important?
    ronfrank - 回复
  10. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 10 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 10 中的图像 2,2
    • 轻轻剥下覆盖电池板数据线接口的小胶带。
    • 胶带与带状电缆集成在一起,不会完全分离。简单地将其向后剥离以接触到接口。
    While the tape in this step was definitely attached to the ribbon cable, I accidentally pulled it off during Step 9, thinking that it was a tab to remove the larger tape covering the whole battery connector. It didn’t seem to do any harm.
    cdowney - 回复
  11. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 11 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 11 中的图像 2,2
    • 使用一个撬棒的尖端翻转小的黑色锁定标签,以确保电缆在其接口。
    Be very careful here. I had to repeat this procedure several times on my MacBook Pro to replace faulty monitors. Eventually, after being opened and closed so many times, the small black locking tab came right off of the connector. Now my battery connection is broken and I can only use my MacBook when it is plugged into the power supply. I’m trying to find a way to securely connect the battery cable without this little locking tab (maybe with tape or something), but so far no luck. Does anyone at iFixit have any advice for me?
    Jamie Near - 回复
    Like Jamie said, use mass amounts of caution here. The lever is very fragile, and mine came off as well - and I’m not exactly a muscular guy. Without it, the connection cannot be made to the data connector, and the computer will not think that a battery is installed. I had to finagle my connector with tweezers and a spudger back into place (and the picture above makes it look normal sized. The picture lies. It is TINY! We’re talking smaller than a small eyelash tiny), and then used some of the adhesive battery strip to hopefully keep it in place.
    Wayne Linder - 回复
    The previous comments are not exaggerated. There ain’t NOTHIN’ to that locking bar. I found it helpful to zoom in with my phone to work on it. It really requires no force to move, I imagine the tape is there to hold it down.
    William Brittain - 回复
  12. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 12 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 12 中的图像 2,2
    • 将电池板数据线从插座中滑出,断开。
    • 沿着电缆的方向平行于主板滑动。
  13. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 13 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 13 中的图像 2,2
    • 将电池板数据线折叠到一边,不要挡道。
    The cable is held down with adhesive. Be very gentle with the delicate cable as you peel it back.
    dkraemer2 - 回复
  14. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 14 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 14 中的图像 2,2
    • 使用T5 Torx 螺丝刀,以移除 3.7 mm 圆形螺丝固定电池电源接口。
    Why is my screwdriver not turning even when I have the correct screwdriver and the screw is not stripped
    Jia Liu - 回复
  15. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 断开电池: 步骤 15 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 断开电池: 步骤 15 中的图像 2,2
    • 轻轻地断开电池接口,用小撬棒轻轻地拔出电池。
    • 将接口抬得足够高,使其与插座保持分离。如果在维修过程中意外接触,可能会损坏MacBook Pro。
    Dies ist kein Stecker sondern eine Kontaktplatte, die nur leicht angehoben werden muss. Dann am besten mit etwas Tesafilm isolieren.
    SchroedersKater - 回复
    (Translation for myself and others; Thanks for the nice tip by the way!) This is not a plug but a contact plate that only needs to be lifted slightly. Then it is best to isolate with some scotch tape.
    S Woo -
  16. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板接口: 步骤 16 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板接口: 步骤 16 中的图像 2,2
    • 使用T3 Torx 螺丝刀拆下两个1.8 mm 螺丝固定轨迹板电缆接口支架。
    You should use T4 here as T3 will strip your screw head
    Ivan Sorkin - 回复
    For me a T4 does NOT work - I needed a T3 Torx screwdriver.
    ian jeffreys - 回复
    t4 for me, better check beforehand so you don’t strip. Don’t think the box stores are going to carry these
    pauljankowiak - 回复
    The T3 works fine. Just be really careful. Keep the tool upright, maintain plenty of pressure and work slowly.
    Ross Wallace - 回复
    Why does my kit not have a t3 bit? I have p5, p5, t5 and t8
    Johnd - 回复
  17. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 17 中的图像 1,1
    • 用一对镊子拆卸触控板电缆接口支架。
  18. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 断开触控板: 步骤 18 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 断开触控板: 步骤 18 中的图像 2,2
    • 用一个撬棒将触控板的连接线从主板上直接撬开,从而断开触控板的色带线。
    If you are removing the logic board, you can skip the rest of the trackpad removal steps. Just fold the cable back out of the way and the track pad can stay in place.
    Troy Reimche - 回复
  19. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 加热触控板电缆: 步骤 19 中的图像 1,1
    • 准备一个 iOpener 并把它放在触控板带电缆的顶部大约一分钟,以软化粘合剂固定触控板带电缆到电池顶部。
    • 如果你没有iOpener,用吹风机加热电缆代替。电缆应该是温暖的,但不要太热触摸。小心不要使电池过热。
  20. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 剥离触控板电缆: 步骤 20 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 剥离触控板电缆: 步骤 20 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 剥离触控板电缆: 步骤 20 中的图像 3,3
    • 小心地将触控板带线从电池上剥离,并将其推到一边。
    • 请勿折叠或撕裂电缆。
    If you are changing the batter you don’t need to remove the logic board and you can jump to step 64. It can say you a lot of time. But there is one trick you need to do. It can be tricky getting the cable under the logic board but I ended up breaking the plastic “wall” that holds the centre battery and you can slide the cable in and just glue back the wall.
    ian jeffreys - 回复
    I believe at this point you skip to Step 77 if you are not using adhesive remover and not removing the logic board. Ian Jeffreys picture of the plastic "wall" is very useful.. (see comments at the end, he has the JPG posted there.)
    William Tzouris - 回复
    Can confirm to have skipped removing of track pad and logic board etc. Right after this step I started to remove the battery (no liquids, used a plastic card only). Please note that when placing the new battery you need start with the battery cable first by sliding the upper left corner of the cable under the area of the trackpad cable connector (compare with pics in step 18). Next place the battery board by lifting the battery connector to more than 90 degrees up (compare with pics in step 15). Then you need to slide the upper right of the battery cable under the area right next to the battery connector. Once the upper part of the battery cable with the battery board is set in place you can start to peel away the liner to expose the adhesive of the new battery, position the battery and set it into place too.
    Ididit - 回复
    Since I only want to remove the battery and am not using any solvents, I also skipped most of the rest of the steps after this to remove the battery. Just using some heat and a card to separate the adhesive and the bending the battery connector to get it out from under the board means you need not remove all the other stuff to protect from solvents.
    johann beda - 回复
  21. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板螺丝: 步骤 21 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板螺丝: 步骤 21 中的图像 2,2
    • 使用T5 Torx 螺丝刀拆下十颗固定触控板总成的螺丝:
    • 两个4.3 mm 螺丝
    • 八个5.8 mm 螺丝
    johann beda - 回复
  22. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 22 中的图像 1,2 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换: 步骤 22 中的图像 2,2
    • 稍微打开显示器来访问触控板。
    • 小心地将触控板带线穿过MacBook Pro框架上的洞。
  23. 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板: 步骤 23 中的图像 1,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板: 步骤 23 中的图像 2,3 2016年晚期13寸带Touch Bar的 MacBook Pro 触控板更换, 移除触控板: 步骤 23 中的图像 3,3
    • 移除触控板组件。
    • 确保不要丢失位于触控板底部的六个小垫圈(两个圆形和四个长方形)。
    This is all you have to do. Slip the battery into your machine where the old one was, run the ribbon cables from the center battery under the motherboard, run the battery data connector to its very sensitive connection to the motherboard, screw in two other screws to hold the battery “chip” in place, screw in the pancake screw and you’re good. There’s no need to remove the motherboard for this installation.
    Sean C McKean - 回复
    Why need to Remove the trackpad assembly? For what?
    Oleg Kolmak - 回复
    I wish I had read what others said here and watched other videos on youtube. This guide is a disaster. You will end up destroying your logic board. Why this idiot did it this way I can’t under stand. Thanks for nothing you &&^&. I’m having to replace my entire logic board. I could just as easily slipped the old battery cable out from under the logic board. Grrrrrrr. Your guide is $@$* and was so difficult to put everything back together. My fan runs continuously at full speed.
    Christian - 回复
    I have to agree I’m using the floss method and not removing the motherboard I did this with a 2012 and a 2013 retina MacBook Pro when changing batteries and those computers are still going strong
    I was able to remove and replace the battery without removing the logic board and easily saved half the work.
    It's not easy to get the data cables under the corners of the logic board but it you push the whole assembly to the right and get the left one under first, then carefully twist the right side under the logic board you can save about 90 minutes of work
    Practice with the old battery.
    Also: I leave the tape backing on and assemble and test first. You'd hate to have to unglue a doa battery!
    Reviving the track pad is to avoid getting the adhe adhesive remover into the track pad. It's easy enough to do I will do that step.
    awr - 回复
    Anyone has an aswer to why my touchpad is extremely sensitive? the slightest touch send it into a clicking frenzy
    daanstevens333 - 回复
结论
请按逆序重组你的设备。
4等其他人完成本指南。
由衷感谢以下译者:
en zh
94%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,426 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,527篇指南
2条评论
Great guide. Thanks for posting. One thing it assumes however, is that the replacement trackpad you’re using came with a data cable (i.e. there is no Step 23 regarding removing the data cable from the old trackpad and re-using it). I’m not sure if it’s always been this way, but the replacement trackpads iFixit sells now for this laptop do not come with a data cable. I had to re-use the data cable from the old trackpad. It wasn’t too difficult to pull the cable up and out of the connector on the old trackpad, and there is no locking tab or anything to flip up to remove it. But it was hard to get the cable back into the connector on the new trackpad with the left over adhesive and the angle of the connector. I was able to get it connected after a few careful attempts, and the trackpad works after re-assembly. Maybe in the past, the replacement trackpads iFixit sold came with a new data cable attached, but it’s worth noting that they currently do not, and you have to supply one.
cdowney - 回复
Actually, the grey bar is a locking tab-the cable might work if you just pull it/shove it in, but do yourself a favor and flip it up with a spudger like other locking tabs. I tried shoving it but neither the touchpad or keyboard worked when i did that
Spider -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 78
总计 10,642
