跳转到主内容
2015 Toyota Camry Purge Valve Replacement
你所需要的
  1. 2015 Toyota Camry Purge Valve Replacement, Purge Valve: 步骤 1 中的图像 1,2 2015 Toyota Camry Purge Valve Replacement, Purge Valve: 步骤 1 中的图像 2,2
    • Locate the purge valve on the engine. It is on the exhaust manifold near the cylinder head. It may have a round plastic gas cap at one end and a flange with an electrical connector at the other end.
  2. 2015 Toyota Camry Purge Valve Replacement: 步骤 2 中的图像 1,3 2015 Toyota Camry Purge Valve Replacement: 步骤 2 中的图像 2,3 2015 Toyota Camry Purge Valve Replacement: 步骤 2 中的图像 3,3
    • Use a Cross slot/Phillips screwdriver and take out the screw that is used to hold the purge valve in place. Rotate the screwdriver to the left until the screw is fully out.
  3. 2015 Toyota Camry Purge Valve Replacement: 步骤 3 中的图像 1,2 2015 Toyota Camry Purge Valve Replacement: 步骤 3 中的图像 2,2
    • Disconnect the electrical connector from the purge valve by gently pulling it away from the valve.
  4. 2015 Toyota Camry Purge Valve Replacement: 步骤 4 中的图像 1,1
    • Apply a few drops of WD-40 at the bottom and right hose to loosen them and make removing them more manageable.
  5. 2015 Toyota Camry Purge Valve Replacement: 步骤 5 中的图像 1,3 2015 Toyota Camry Purge Valve Replacement: 步骤 5 中的图像 2,3 2015 Toyota Camry Purge Valve Replacement: 步骤 5 中的图像 3,3
    • You should be able to remove the hose's by hand but use a slip joint pillar if it is difficult. The hose's should then simply slide off and in doing so gently lift the valve away from the engine.
  6. 2015 Toyota Camry Purge Valve Replacement: 步骤 6 中的图像 1,1
    • Now that you have removed the part, you may connect the new purge valve of your choice.
结论
另外一个人完成了本指南。
Eduardo Guzman
于04/04/23注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-15, Briggs Spring 2023 CSU Los Angeles, Team 1-15, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S1G15
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 62
过去 30 天: 276
总计 2,418
