跳转到主内容
2015 Mini Cooper Key Fob Battery Replacement
你所需要的
  1. 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,2 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,2
    • Using a plastic opening tool, create leverage in the corner of the backplate.
    • Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
    • Repeat on the other side.
  2. 2015 Mini Cooper Key Fob Battery Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool in the notch on the front of the key fob and pry up the backplate in the center until it pops off.
    • If you hear cracking, make sure both the corners are detached.
  3. 2015 Mini Cooper Key Fob Battery Replacement: 步骤 3 中的图像 1,2 2015 Mini Cooper Key Fob Battery Replacement: 步骤 3 中的图像 2,2
    • Press the silver button on the side of the neck, and pull the key out.
    • Insert the key into the latch on the back of the battery casing, above the slot where it comes out. Pull up and out.
    • If the backing doesn't come out easily, take the key out and try again.
  4. 2015 Mini Cooper Key Fob Battery Replacement: 步骤 4 中的图像 1,1
    • Use your finger to press down and forward on the battery. It should pop out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 152
总计 7,232
