跳转到主内容
2015 BMW 320i Rear Bumper Trim Replacement
你所需要的
  1. 2015 BMW 320i  Rear Bumper Trim  Replacement, 2015 BMW 320i Rear Bumper Trim: 步骤 1 中的图像 1,1
    • The Rear Tailgate Trim is located on the backside of the car.
  2. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 2 中的图像 1,1
    • Remove the damaged trim by gently prying it off with a flathead screwdriver.
    • Insert the screwdriver between the car and the trim slowly and gently to avoid scratching your car.
    • Apply pressure on the trim and listen for a "POP" noise.
  3. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 3 中的图像 1,1
    • Once you hear the "POP," grab the trim and pull it towards you.
    • Go across and pull each part of the trim towards you until the whole trim is detached.
    • There are several clips along the edge of the trim holding it in place. The "POP" sounds are caused by those clips disengaging.
  4. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 4 中的图像 1,1
    • This is how the trim area should appear after removal.
    • Prepare for the replacement portion of the repair by setting aside the old damaged trim.
  5. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 5 中的图像 1,2 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 5 中的图像 2,2
    • Unwrap your new BMW rear trunk chromatic trim.
    • Check for any damaged parts on your new trim. If there is any damage do not use it.
  6. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 6 中的图像 1,1
    • Your new rear trim should have clip tabs throughout the backside of the trim.
    • Line up the clip tabs with the holes on the empty trim area of your vehicle.
    • If your new trim is a missing a tab for any reason, this trim will not work and you will need to discard or return your new trim, because the repair can not be complete with any tabs missing.
  7. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 7 中的图像 1,3 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 7 中的图像 2,3 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 7 中的图像 3,3
    • Firmly push the clip tabs into each of the holes on the bumper of your car.
    • You should hear a click sound as the clip engages.
    • Start at either end of the trim and move along in a line until all the clips are engaged.
  8. 2015 BMW 320i  Rear Bumper Trim  Replacement: 步骤 8 中的图像 1,1
    • Your new trim should be all done!
    • Double check for any extra space along the top of the trim. There should not be any space that can be seen.
结论
Once you have completed these steps your car will once again have an enhanced appearance!
另外一个人完成了本指南。
Taylor Wilson
于02/18/21注册
181 声望
撰写一个指南
团队
Texas Tech, Team S3-G24, Cowan Spring 2021 Texas Tech, Team S3-G24, Cowan Spring 2021 的会员
TTU-COWAN-S21S3G24
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 876
