跳转到主内容
2015-2021 Volkswagen GTI Cabin Air Filter Replacement
你所需要的
  1. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 3,3
    • Open Glove Compartment.
    • Locate the two tabs on the corners of the glove compartment.
    • Push up on both tabs. One at a time or simultaneously.
    • Drop down the glove compartment.
  2. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 2 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 2 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 2 中的图像 3,3
    • After dropping down the glove compartment, locate the honeycomb compartment.
    • Behind the compartment is the old cabin air filter.
    • Located on the compartment are three clips. The clips are on the top section of the compartment.
    • To unlatch the three clips, apply pressure onto a flap on the right side while carefully unhooking each clip.
  3. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 3 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 3 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 3 中的图像 3,3
    • After removing the honeycomb compartment, set it aside.
    • Remove the old cabin air filter and throw it out.
    • If the filter does not slide out immediately, try pinching on the filter and pulling it out.
  4. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 4 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 4 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 4 中的图像 3,3
    • When installing the new air filter, notice the direction of the arrows on your old one.
    • Make sure to have the air flow arrows facing the same way (down). Push into the empty compartment.
  5. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 5 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 5 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 5 中的图像 3,3
    • Now we put the honeycomb compartment back.
    • Make sure to insert the lower tab into the slot.
    • It will stay ajar, to seal the compartment, simply apply pressure on the compartment.
    • It will click into place, but to be sure press along the edges.
  6. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 6 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 6 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 6 中的图像 3,3
    • Putting the glove compartment back.
    • Follow these steps to follow in order.
    • First, push up on the glove compartment until it clicks.
    • Second, make sure the brake element is assembled; the stick goes into the circular module.
    • Finally, push the glove compartment until you hear the second click.
  7. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 7 中的图像 1,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 7 中的图像 2,3 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: 步骤 7 中的图像 3,3
    • After hearing the second click, the glove compartment should remain open.
    • Finally, you can close the glove compartment.
结论
Hector C.
于03/20/24注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-5, Harris Spring 2024 CSU Los Angeles, Team 1-5, Harris Spring 2024 的会员
CSULA-HARRIS-S24S1G5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 76
总计 239
