简介
如果你的 盖乐世 A3无法充电,你可以使用本指南更换耗尽的电池。
本指南涉及移除显示屏和中框。你需要更换粘合剂才能重新连接显示屏,不然容易破坏手机。
在拆卸手机之前,请将电池放电至25%以下。如果意外被刺破,电池会着火和/或爆炸,但如果放电,发生这种情况的可能性要低得多。
你所需要的
请按逆序重新组装。如有必要重新涂抹胶水。
45等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
11条评论
Ich habe die Metallfolie abgemacht und jetzt geht das Handy gar nicht mehr an! Ist das normal oder müsste es zumindest einmal vibrieren, selbst wenn kein LCD angeschlossen ist? Habe noch sehr wichtige Daten auf dem Handy ….
Why does it not mention that the screen is glued to the frame (not just around the edges)? I have now found the ifixit guide for replacing the screen that says “NOTE: The LCD is also glued to the frame and will most likely break when removing the display“. Seems a pretty important bit of information to leave out of this article when the screen needs to be removed in one piece, and one that’s just cost me a screen. Not happy.
Actually, he does say it. Esta guía incluye cómo quitar la pantalla y el marco intermedio. Necesitarás adhesivo de reemplazo para volver a pegar la pantalla. —>>>> La pantalla LCD también está pegada al marco y podría romperse al abrir el teléfono. <<<<—
Do you really have to take the screen off just to replace the back cover
m.brown350 - 回复
There is no real back cover, rather a complete casing. Unfortunately the display is the only way in.
Yes, I agree with Alex, I have just cut through the glue that is around the frame and then tried to pry the screen up but was never aware that the screen is glued to the entire phone underneath. Caused the screen to crack and doesn’t work anymore. It should be clear that the screen is completely glued down.
Excelente!!!! Gracias
Même remarque que Tom et Alex, l’écran est TOTALEMENT collé au chassis ce qui rend l’opération de dépose vraiment délicate car il faut chauffer fortement l’écran pour le retirer, chose que je n’ai pu faire sans le briser.
Donc à vouloir changer la batterie, je dois maintenant changer l’écran.
Il faut bien dire que la dépose de l’écran est une opération très risquée pour l’écran lui-même et délicate car le risque de casse est élevé.
Je ne vous remercie pas car je suis bon pour acheter un nouvel écran…
John Locke - 回复
Nous sommes désolés d’apprendre cela et avons adapté le texte en espérant qu’il reflète mieux le risque maintenant.
La réparation a bien fonctionné pour moi . Malheureusement la batterie achetée en même temps que le kit n'a tenu que 6 MOIS !!!!!
Je suis contente davoir réussit la manip mais extrêmement déçue de la qualité de la batterie.
Bonjour @kldre !
Désolée d’apprendre que vous rencontrez un problème. Je vous conseille de prendre contact directement avec le fournisseur de la batterie. Si vous l’avez achetée chez iFixit, veuillez écrire au support@ifixit.com (pour la boutique américaine) ou au eustore@ifixit.com (pour la boutique européenne et française).
Ce sera un plaisir de vous aider !
