跳转到主内容
2014-Present Kia Soul Side Mirror Replacement
你所需要的
  1. 2014-Present Kia Soul Side Mirror Replacement, Side Mirror: 步骤 1 中的图像 1,2 2014-Present Kia Soul Side Mirror Replacement, Side Mirror: 步骤 1 中的图像 2,2
    • Slide the prying tool behind the interior cover, along the edge next to the windshield.
    • Pry the plastic cover from the top until it pops out.
    • When the cover is loose, gently pull it off.
  2. 2014-Present Kia Soul Side Mirror Replacement: 步骤 2 中的图像 1,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 2 中的图像 2,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 2 中的图像 3,3
    • Squeeze the white tab and gently remove the electric cable connector.
    • When removing the electric cable connector, be careful not to pull the wires out.
  3. 2014-Present Kia Soul Side Mirror Replacement: 步骤 3 中的图像 1,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 3 中的图像 2,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 3 中的图像 3,3
    • Use a 10 mm socket wrench to remove the three 10 mm bolts holding the mirror to the window.
  4. 2014-Present Kia Soul Side Mirror Replacement: 步骤 4 中的图像 1,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 4 中的图像 2,3 2014-Present Kia Soul Side Mirror Replacement: 步骤 4 中的图像 3,3
    • When working on this step, hold onto the side mirror to prevent it from falling. It may be helpful to have someone assist you during this step.
    • Use needle nose pliers to grip the grommet (plastic anchor around the screw) and guide it through the hole to detach the side mirror from the car.
    • Make sure to clamp all four sides of the grommet simultaneously to guide it through the opening. Do not turn or remove the screw during this process.
  5. 2014-Present Kia Soul Side Mirror Replacement: 步骤 5 中的图像 1,2 2014-Present Kia Soul Side Mirror Replacement: 步骤 5 中的图像 2,2
    • Remove the side mirror from the car.
    • It should come off in one piece.
    • Be careful to not drop the side mirror as the fragile glass could shatter.
  6. 2014-Present Kia Soul Side Mirror Replacement: 步骤 6 中的图像 1,1
    • Position the new side mirror in the same place where the damaged mirror was removed.
    • Make sure that the holes of the new side mirror line up with the holes in the door.
    • Ensure that the grommet for the new side mirror passes through the same opening from which the damaged side mirror grommet was removed from in Step 4.
结论
Alex D
于02/01/24注册
133 声望
撰写一个指南
团队
York University, Team M-3, Allen Winter 2024 York University, Team M-3, Allen Winter 2024 的会员
YORK-ALLEN-W24SMG3
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 332
