跳转到主内容
加入维修社区 - 创建账户
2014-Present Kia Sedona Cargo Lamp Bulb Replacement
你所需要的
  1. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Remove the lens cover: 步骤 1 中的图像 1,1
    • The lens cover has six plastic tabs that hold it in place.
    • The two rear tabs are larger and harder to unclip.
  2. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 步骤 2 中的图像 1,3 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 步骤 2 中的图像 2,3 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 步骤 2 中的图像 3,3
    • These tabs are very stiff. Take your time and be careful not to scratch the plastic. You may need to use a bit of force to unclip these.
    • Insert a metal spudger or a small flathead screwdriver into the front seam near the toggle switch.
    • Pry to release the front tabs.
    • Use a spudger or Jimmy to pry and release the side tabs.
    • Tilt and wiggle the lens cover until the rear tabs release.
    • Remove the lens cover and the gray cover plate behind it.
  3. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Replace the bulb: 步骤 3 中的图像 1,1
    • Pull the bulb out of its two clips and remove it.
  4. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 步骤 4 中的图像 1,3 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 步骤 4 中的图像 2,3 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 步骤 4 中的图像 3,3
    • Align and stack the lens cover and gray cover plate together
    • Insert the two larger rear tabs into their recesses.
    • Press the covers into place until all tabs click into place.
终点
Arthur Shi
于01/03/18注册
329,047 声望
创作了810篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 53
