跳转到主内容
2014 Subaru Impreza Hatchback Brake light Replacement
你所需要的
  1. 2014 Subaru Impreza Hatchback Brake light Replacement, Brake Light: 步骤 1 中的图像 1,1
    • Turn off car engine
  2. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 2 中的图像 1,1
    • Open the trunk of the car.
  3. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 3 中的图像 1,1
    • Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
    • Unscrewing them will allow you to take out the brake light.
  4. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 4 中的图像 1,2 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 4 中的图像 2,2
    • Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
  5. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 5 中的图像 1,1
    • Gently pull the rear light straight back.
  6. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 6 中的图像 1,1
    • Upon opening the brake light, you should see three bulbs in total.
    • The brake light is the one on the bottom.
  7. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 7 中的图像 1,2 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 7 中的图像 2,2
    • To remove the brake light, twist the light bulb socket counterclockwise.
    • The bulb should come out as shown in the second image.
  8. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 8 中的图像 1,1
    • To remove the bulb, gently pull out the bulb from its connector.
  9. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 9 中的图像 1,1
    • Gently insert the new bulb into the connector.
    • Carefully insert the bulb, as the bulb is made of glass it is susceptible to breaking and cutting you if a lot of force is used to insert it in the connector.
  10. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 10 中的图像 1,2 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 10 中的图像 2,2
    • Reinsert the bulb back into its initial position.
    • Gently twist the bulb clockwise to further tighten the bulb.
  11. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 11 中的图像 1,1
    • Gently push the rear light cover back into its initial place.
  12. 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 12 中的图像 1,2 2014 Subaru Impreza Hatchback Brake light Replacement: 步骤 12 中的图像 2,2
    • Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
终点
另外一个人完成了本指南。
Manas Tripathi
于01/16/23注册
232 声望
撰写一个指南
团队
York University, Team N-5, Morris Winter 2023 York University, Team N-5, Morris Winter 2023 的会员
YORK-MORRIS-W23SNG5
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 66
总计 1,225
