跳转到主内容
2014 Subaru Forester Headlight Replacement
你所需要的
  1. 2014 Subaru Forester Headlight Replacement, Low-Beam Headlights: 步骤 1 中的图像 1,1
    • Make sure you have the correct replacement part. For the specified model, the H11 Headlight Bulb is the stock-standard replacement bulb (found at any automotive store).
  2. 2014 Subaru Forester Headlight Replacement: 步骤 2 中的图像 1,3 2014 Subaru Forester Headlight Replacement: 步骤 2 中的图像 2,3 2014 Subaru Forester Headlight Replacement: 步骤 2 中的图像 3,3
    • Open the hood of your car by locating and pulling the hood release found on the driver side dash just below (and to the left) of the steering wheel. Then move to the front grill of your car and pull the latch located under the Subaru symbol.
  3. 2014 Subaru Forester Headlight Replacement: 步骤 3 中的图像 1,3 2014 Subaru Forester Headlight Replacement: 步骤 3 中的图像 2,3 2014 Subaru Forester Headlight Replacement: 步骤 3 中的图像 3,3
    • Move to the side that harbors the burnt-out headlight. Locate the headlight assembly which is positioned right behind the headlight itself.
  4. 2014 Subaru Forester Headlight Replacement: 步骤 4 中的图像 1,2 2014 Subaru Forester Headlight Replacement: 步骤 4 中的图像 2,2
    • Reach inside the headlight assembly to find the base of the bulb. Push in the release tab (which is the indention found on the base below the blue tag), then move the power plug downward from the old bulb with above-moderate force.
  5. 2014 Subaru Forester Headlight Replacement: 步骤 5 中的图像 1,2 2014 Subaru Forester Headlight Replacement: 步骤 5 中的图像 2,2
    • Grab the base of the old bulb and rotate it a quarter length counterclockwise and then you will be able to pull it straight out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 125
总计 9,242
