跳转到主内容
加入维修社区 - 创建账户
2014 Nissan Juke Key Fob Battery Replacement
你所需要的
  1. 2014 Nissan Juke Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,1
    • Flip your key to the back of the key fob.
    • Remove the emergency key from the key fob.
    询问修复机器人
    添加评论
  2. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 2 中的图像 1,2 2014 Nissan Juke Key Fob Battery Replacement: 步骤 2 中的图像 2,2
    • Gently insert a spudger into a corner of the key fob casing.
    • Push up the spudger to remove both halves of the key fob from each other.
    • Be careful when trying to find a good corner to separate the halves so that the spudger does not stab you.
    询问修复机器人
    添加评论
  3. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 3 中的图像 1,1
    • Open up your key fob and look at all the components in your key fob.
    • Pay attention to what side the old battery is facing; it will be helpful for the next step.
    询问修复机器人
    添加评论
  4. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the old CR2032 battery.
    • Pay attention to what side the old battery was facing.
    询问修复机器人
    添加评论
  5. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 5 中的图像 1,2 2014 Nissan Juke Key Fob Battery Replacement: 步骤 5 中的图像 2,2
    • Place the new battery in the same position and side the old CR2032 battery was in.
    询问修复机器人
    添加评论
  6. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 6 中的图像 1,1
    • Make sure the positive and negative sides are facing the correct direction to ensure that the key fob will work properly.
    询问修复机器人
    添加评论
  7. 2014 Nissan Juke Key Fob Battery Replacement: 步骤 7 中的图像 1,2 2014 Nissan Juke Key Fob Battery Replacement: 步骤 7 中的图像 2,2
    • Take the two halves of your key fob and snap them together.
    • When snapping them back together be careful to not pinch yourself during the process.
    • Make sure you hear the "snap" sound so that you know the halves have been successfully put back together.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Devin wallace
于01/21/25注册
148 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 90
总计 791
