跳转到主内容
2014 Fiat 500L Rear Windshield Wiper Replacement
你所需要的
  1. 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: 步骤 1 中的图像 1,2 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: 步骤 1 中的图像 2,2
    • Gently lift the wiper off of the window to begin.
  2. 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 2 中的图像 1,2 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 2 中的图像 2,2
    • Using your thumb, push the wiper away from you and out of place. You will hear it click when it is coming off.
  3. 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 3 中的图像 1,2 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 3 中的图像 2,2
    • Position the new blade to where it aligns perfectly with the existing wiper arm.
    • There is an ident on the existing wiper arm that the new wiper will fit into.
  4. 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 4 中的图像 1,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 4 中的图像 2,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 4 中的图像 3,3
    • Place your thumbs on the top of the wiper and your other fingers on the under side of the wiper, to put the wiper into place.
    • You will hear it click when it is locked into place.
  5. 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 5 中的图像 1,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 5 中的图像 2,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 5 中的图像 3,3
    • Gently rest the wiper against the windshield.
  6. 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 6 中的图像 1,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 6 中的图像 2,3 2014 Fiat 500L Rear Windshield Wiper Replacement: 步骤 6 中的图像 3,3
    • Test out the new wiper.
    • Turn your car on and switch your wiper on. The new blade will fall off of the wiper arm if it is not fully attached. If it is fully attached, the wiper will work successfully.
终点
3等其他人完成本指南。
Sierra Sparre
于10/30/18注册
214 声望
撰写一个指南
团队
UC Davis, Team S1-G4, Bender Fall 2018 UC Davis, Team S1-G4, Bender Fall 2018 的会员
UCD-BENDER-F18S1G4
3 名成员
创作了1篇指南
一条评论
Thanks for this...all other videos were wrong. I needed the step by step pics.
Sandra Watkins - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 17
总计 1,916
