跳转到主内容
2014-2016 Toyota Corolla Engine Air Filter Replacement
你所需要的
  1. 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: 步骤 1 中的图像 1,2 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: 步骤 1 中的图像 2,2
    • Open the hood of your Corolla by pulling the hinge at the bottom of your dash and hold it up using the hood lift support.
    • Pull the hinge in the lower part of your driver-side dashboard. It should have an icon of a vehicle with its hood up.
    • Once you pull it, open up the hood and use the support located at the center of the engine bay to hold the hood up.
  2. 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 2 中的图像 1,3 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 2 中的图像 2,3 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 2 中的图像 3,3
    • Find air filter box and unclip the clips on the air filter's sides.
    • Take your hand to the clips and pull them slightly. You can remove the top of the air filter box if done right.
  3. 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 3 中的图像 1,2 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 3 中的图像 2,2
    • Hold the air filter top up and pull out the old air filter.
    • Once old air filter is removed, get your new one and line up the square corner of the filter with the square corner of the air filter box.
    • Insert the new air filter with this orientation.
  4. 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 4 中的图像 1,3 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 4 中的图像 2,3 2014-2016 Toyota Corolla Engine Air Filter Replacement: 步骤 4 中的图像 3,3
    • Clip back the clips on the sides of the air filter box to close it.
    • Congratulations, you have successfully replaced the air filter in your Corolla.
结论
Congratulations, you have replaced the air filter in your Corolla.
另外一个人完成了本指南。
Romer Pena
于09/20/23注册
136 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 57
过去 30 天: 192
总计 480
