跳转到主内容
2013 Toyota Camry Rear Brake Light Bulb Replacement
你所需要的
  1. 2013 Toyota Camry Rear Brake Light Bulb Replacement, Rear Brake Light Bulb Replacement: 步骤 1 中的图像 1,1
    • Be sure that your car is completely turned off.
    • Pop the trunk open.
  2. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 2 中的图像 1,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 2 中的图像 2,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry out the two smaller fasteners inside the trunk.
    • Push on the hook fastener to remove it.
  3. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 3 中的图像 1,2 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Peel back the canvas on the side where you are replacing the bulb.
    • You will begin to see the cables connected to the rear light.
  4. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 4 中的图像 1,1
    • You will see three connections; a brake light, a turn signal light, and a parking light.
    • The one we will be replacing is the brake light bulb, the biggest connection of the three.
  5. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 5 中的图像 1,2 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 5 中的图像 2,2
    • Turn the bulb counterclockwise from the outer connection portion (the black part).
    • Pull the old light bulb from its connection.
    • This may be a bit difficult to pull apart, but not tools are required.
  6. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 6 中的图像 1,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 6 中的图像 2,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Before handling the new light bulb, wear latex gloves or something to cover your hands. Handling the bulb with bare hands will shorten the light bulb's life span.
    • Plug the new light bulb into the connection by pushing until you hear a click.
  7. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 7 中的图像 1,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 7 中的图像 2,3 2013 Toyota Camry Rear Brake Light Bulb Replacement: 步骤 7 中的图像 3,3
    • Place the connection into its slot and turn it clockwise to ensure it stays in place.
    • Follow Steps 2 and 3 in reverse.
终点
另外一个人完成了本指南。
Chris
于11/14/22注册
170 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-40, Briggs Fall 2022 CSU Los Angeles, Team 2-40, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G40
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 59
总计 878
