跳转到主内容
2013 Subaru Legacy Oil and Oil Filter Replacement
你所需要的
  1. 2013 Subaru Legacy Oil and Oil Filter Replacement, Oil and Oil Filter: 步骤 1 中的图像 1,2 2013 Subaru Legacy Oil and Oil Filter Replacement, Oil and Oil Filter: 步骤 1 中的图像 2,2
    • Drive slowly onto ramps to prop up your Subaru Legacy.
    • Don't forget to turn on your parking break and block the rear wheels with wheel chocks or 2x4 wood blocks.
    • Align the oil pan on the Legacy with the oil pan you're using to collect the oil being drained.
    • Place newspaper around the pan to catch spatters.
  2. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 2 中的图像 1,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 2 中的图像 2,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 2 中的图像 3,3
    • Loosen the drain bolt with your 17mm socket wrench just enough to where you're able to loosen the rest by hand.
    • Remove the bolt and washer by hand to allow the oil to drain into the oil pan.
  3. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 3 中的图像 1,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 3 中的图像 2,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 3 中的图像 3,3
    • Once your Legacy is completely empty of oil, clean off the bolt and washer and tighten them by hand until you can't turn it anymore.
    • Turn the bolt another 1.5 turns with the 17mm wrench.
    • Do not over-tighten the bolt.
  4. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 4 中的图像 1,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 4 中的图像 2,3 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 4 中的图像 3,3
    • On a 2013 Subaru Legacy the oil filter should be by the battery. Loosen the oil filter by hand if possible. If not, use an oil wrench or a crescent wrench to loosen it.
    • Be cautious while removing the oil filter to ensure you won't spill any oil.
    • Clean the tray around the oil filter after you remove it with a paper towel.
  5. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 5 中的图像 1,2 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 5 中的图像 2,2
    • Rub a little bit of the new oil you bought onto the new oil filter's gasket.
    • Screw on the new oil filter by hand until it is tight. You don't have to use the wrench to tighten the filter.
    • The type of oil filter required for your Legacy should be listed in the owner's manual.
  6. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 6 中的图像 1,2 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 6 中的图像 2,2
    • Fill your car with the oil mentioned in your owner's manual.
    • The owner's manual should mention the type of oil as well as the amount needed for your engine.
  7. 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 7 中的图像 1,2 2013 Subaru Legacy Oil and Oil Filter Replacement: 步骤 7 中的图像 2,2
    • Remove the dipstick and clean it. Then reinsert it and remove it again and ensure the second dot on the end of the dipstick is touched by oil.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 1,749
