跳转到主内容
2013 Nissan Altima Interior Door Handle Replacement
你所需要的
  1. 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 步骤 1 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 步骤 1 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 步骤 1 中的图像 3,3
    • Use an opening tool or spudger to gently pry open the cover behind the door handle.
    • Use a 10 mm socket to remove the bolt under the handle cap.
  2. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 2 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 2 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool or spudger to pry the window and door lock assembly up and free from the frame.
    • Use a 10 mm socket to remove the single bolt underneath the control assembly.
  3. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 3 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 3 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 3 中的图像 3,3
    • There is another screw located underneath the long arm panel (to the left of the door handle), unscrew it.
  4. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 4 中的图像 1,1
    • Unhook the cables from the window control panel to take off the door.
  5. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three silver screws directly behind the door handle (Top, left, right).
  6. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 6 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 6 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 6 中的图像 3,3
    • Unhook the two wires that hook into the unlock/lock mechanisms.
  7. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 7 中的图像 1,2 2013 Nissan Altima Interior Door Handle Replacement: 步骤 7 中的图像 2,2
    • Remove the old door handle.
  8. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 8 中的图像 1,2 2013 Nissan Altima Interior Door Handle Replacement: 步骤 8 中的图像 2,2
    • Place and screw the new handle into place.
  9. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 9 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 9 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 9 中的图像 3,3
    • Hook the lock/unlock wires back into the door handle. (Handle will not work unless this step is complete.
  10. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 10 中的图像 1,2 2013 Nissan Altima Interior Door Handle Replacement: 步骤 10 中的图像 2,2
    • Plug in the window control panel and place the panel back in its respectful place.
    • The door panel clips should goes into the holes and snap in when in place.
  11. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 11 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 11 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 11 中的图像 3,3
    • Insert the screw beneath the control panel and the screw to the right of the lock/unlock button.
  12. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 12 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 12 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 12 中的图像 3,3
    • Next, place both the door arm and window control panel in their place. The arm should snap in while the control panel sits flush in place.
  13. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 13 中的图像 1,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 13 中的图像 2,3 2013 Nissan Altima Interior Door Handle Replacement: 步骤 13 中的图像 3,3
    • Lastly, place the screw back in its respective place and tighten it with the rachet.
  14. 2013 Nissan Altima Interior Door Handle Replacement: 步骤 14 中的图像 1,2 2013 Nissan Altima Interior Door Handle Replacement: 步骤 14 中的图像 2,2
    • Finishing result: The older interior handle is in my hand, while the new interior handle is in place.
终点
另外一个人完成了本指南。
Ezzaddin alkabsh
于09/19/22注册
229 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 101
总计 1,217
