跳转到主内容
2013 Honda Civic Headlight Replacement
你所需要的
  1. 2013 Honda Civic Headlight Replacement, Headlight: 步骤 1 中的图像 1,2 2013 Honda Civic Headlight Replacement, Headlight: 步骤 1 中的图像 2,2
    • Lift the latch to open the car hood.
  2. 2013 Honda Civic Headlight Replacement: 步骤 2 中的图像 1,1
    • Pry up the center of the fastener with a flat-head screwdriver.
  3. 2013 Honda Civic Headlight Replacement: 步骤 3 中的图像 1,1
    • Pop the rivet loose and remove it.
  4. 2013 Honda Civic Headlight Replacement: 步骤 4 中的图像 1,1
    • Remove the wiper fluid tube.
  5. 2013 Honda Civic Headlight Replacement: 步骤 5 中的图像 1,1
    • Locate the headlight internally.
    • Turn the headlight counter-clockwise to unlock it.
  6. 2013 Honda Civic Headlight Replacement: 步骤 6 中的图像 1,1
    • Press down on the latch to unlock the bulb from the connector.
    • Remove the burnt-out bulb.
    • Replace with the new bulb.
  7. 2013 Honda Civic Headlight Replacement: 步骤 7 中的图像 1,1
    • Turn clockwise to lock.
终点
3等其他人完成本指南。
2条评论
Used this guide to replace bulb in my 2013 Honda. Clear pictures and accurate wording made replacement understandable snd Easy!
madscientistnbmt - 回复
UK built Civics are different from step 5. Rather than turn the unit anti clockwise there's one of those metal clips you need to unhook by pressing inwards and pushing slightly left (towards the radiator) to release the bulb. Be careful as the stupid clip easily falls out of its hinge slots and you have to do it all by feel and touch as there's no room to see what you're doing.
Stu Magoo - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 193
总计 9,332
