跳转到主内容
2013 Honda Accord Headlight Replacement
你所需要的
  1. 2013 Honda Accord Headlight Replacement, Headlight: 步骤 1 中的图像 1,3 2013 Honda Accord Headlight Replacement, Headlight: 步骤 1 中的图像 2,3 2013 Honda Accord Headlight Replacement, Headlight: 步骤 1 中的图像 3,3
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: 步骤 2 中的图像 1,2 2013 Honda Accord Headlight Replacement: 步骤 2 中的图像 2,2
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: 步骤 3 中的图像 1,2 2013 Honda Accord Headlight Replacement: 步骤 3 中的图像 2,2
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: 步骤 4 中的图像 1,2 2013 Honda Accord Headlight Replacement: 步骤 4 中的图像 2,2
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: 步骤 5 中的图像 1,3 2013 Honda Accord Headlight Replacement: 步骤 5 中的图像 2,3 2013 Honda Accord Headlight Replacement: 步骤 5 中的图像 3,3
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
结论
另外一个人完成了本指南。
Tahsin
于09/19/22注册
145 声望
撰写一个指南
团队
York University, Team A-8, Morris Fall 2022 York University, Team A-8, Morris Fall 2022 的会员
YORK-MORRIS-F22SAG8
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 75
总计 2,487
