跳转到主内容
2013 Chevrolet Camaro Tail-Light Replacement
你所需要的
  1. 2013 Chevrolet Camaro Tail-Light Replacement, Tail Light: 步骤 1 中的图像 1,2 2013 Chevrolet Camaro Tail-Light Replacement, Tail Light: 步骤 1 中的图像 2,2
    • Open the trunk by either the button on the driver side door panel or the key fob.
  2. 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 2 中的图像 1,2 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 2 中的图像 2,2
    • Use your key fob or press on your brakes to identify which bulb needs to be replaced.
    • Identify which bulbs need to be replaced.
    • In this case my driver side outside bulb was blown so that is the one that is getting replaced today.
  3. 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 3 中的图像 1,3 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 3 中的图像 2,3 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 3 中的图像 3,3
    • Unscrew the rubber screw by turning counter clockwise.
    • Gently pull these caps straight up to remove them.
    • The rubber screw can be removed by hand but it would be easier to use the pliers.
  4. 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 4 中的图像 1,3 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 4 中的图像 2,3 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 4 中的图像 3,3
    • Rotate the entire socket a half turn clockwise. After this is done, gently pull the bulb socket from the taillight housing.
    • Remove and dispose of the blown bulb.
  5. 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 5 中的图像 1,2 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 5 中的图像 2,2
    • At this point you can place the new bulb into the plug.
    • When placing the new bulb into the plug be careful to not apply too much pressure. If the plug does not initially snap into place trying turning it and gently push it into place.
  6. 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 6 中的图像 1,2 2013 Chevrolet Camaro Tail-Light Replacement: 步骤 6 中的图像 2,2
    • Before placing the plug back into the housing you should test the bulb to make sure it is in working order.
    • You can test the bulb by locking the door with your key fob or have someone press the brakes.
    • Repeat steps until all lights are in working order.
结论
To reassemble, follow these steps in reverse order.
另外一个人完成了本指南。
Jack Hatcher
于02/11/21注册
136 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 1,266
