跳转到主内容
2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement
你所需要的
  1. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 步骤 1 中的图像 1,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 步骤 1 中的图像 2,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Mount the new camera in the space provided.
    • The camera routes through the bumper of the car and not the license plate.
  2. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 2 中的图像 1,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 2 中的图像 2,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 2 中的图像 3,3
    • Run the new wires through the holes provided, and cover with electrical tape.
    • The new cords will simply connect where the faulty wires were removed.
  3. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 3 中的图像 1,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 3 中的图像 2,3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 3 中的图像 3,3
    • Coordinate the colored wires to keep the repair simple. Match the new wires to the existing wires through the splitter. Use a wire splitter to expose the wire.
    • Then simply connect the wires to the wires for reverse light.
  4. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 4 中的图像 1,1
    • The green wire is the camera connection or positive wire and the black is the ground.
    • This line should already be connected correctly because you should have only switched wires that connected to the camera.
  5. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 5 中的图像 1,1
    • Make sure that the reverse light is working properly when the car is in reverse.
  6. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 步骤 6 中的图像 1,1
    • Make sure the display is clear and working properly.
结论
2等其他人完成本指南。
2条评论
The photos you show in steps 2 & 3 - is that the trunk only?
jrselinger24 - 回复
Hello. I am trying to replace my camera. But not sure how to remove it or where to buy a replacement.
Jonathan Anderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 187
总计 13,194
