简介
本指南将告诉你如何在仅使用钥匙使用2013-2017款钥匙本身来进行更换电池。通过简单的步骤知道,您将很轻松的跟换电池并继续使用。本次跟换仅需要一块全新的电池即可。过程很简单,仅需几分钟。
你所需要的
将福特FORD的标志向上,把点火钥匙插入左侧的凹槽中
用点火钥匙卸下旧的电池
要重新组装您的设备,请将后盖更换牢牢固定。
36等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
16条评论
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
Cathy Hawn - 回复
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Easy Peasy, Thank you!
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
