跳转到主内容
2013-2018 Jeep Wrangler Sun Visor Replacement
你所需要的
  1. 2013-2018 Jeep Wrangler Sun Visor Replacement, Sun Visor: 步骤 1 中的图像 1,1
    • Lower the old sun visor to the lowest position.
  2. 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 2 中的图像 1,2 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 2 中的图像 2,2
    • Locate the screw that secures the sun visor to the mounting bracket.
    • This screw is sometimes covered by a small plastic bracket.
    • Remove the plastic cover using a flathead screwdriver or trim-removing tool
  3. 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 3 中的图像 1,2 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 3 中的图像 2,2
    • Use a Torx T20 or T25 to remove the 12 mm screw that attaches the sun visor to the bracket.
  4. 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 4 中的图像 1,2 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 4 中的图像 2,2
    • Slide the old sun visor off the mounting bracket.
    • Keep the old sun visor and any hardware in case it's needed for the replacement.
  5. 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 5 中的图像 1,2 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 5 中的图像 2,2
    • Slide the new sun visor onto the mounting bracket, aligning the holes for the screws.
  6. 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 6 中的图像 1,3 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 6 中的图像 2,3 2013-2018 Jeep Wrangler Sun Visor Replacement: 步骤 6 中的图像 3,3
    • Insert the screw into the mounting bracket and tighten it with the Torx T25 screwdriver.
    • Make sure it's snug but not too tight.
    • Tightening the screw too tight might damage the plastic.
    • If your sun visor had a plastic cover concealing the screw, put it back in place.
    • Test the new sun visor by moving it into different positions to make sure it functions correctly.
结论
Piper Klein
于09/27/23注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 53
总计 298
