跳转到主内容
2013-2017 款福特汽车钥匙电池更换
你所需要的
  1. 2013-2017 款福特汽车钥匙电池更换, 2013-2017 款福特汽车钥匙电池: 步骤 1 中的图像 1,1
    • 滑动钥匙背面的钥匙解锁开关。
  2. 2013-2017 款福特汽车钥匙电池更换: 步骤 2 中的图像 1,1
    • 从汽车钥匙上取下金属启动钥匙。
    Push the button against the spring and use a fingernail to pry out the key.
    Dan Smith - 回复
  3. 2013-2017 款福特汽车钥匙电池更换: 步骤 3 中的图像 1,1
    • 将福特FORD的标志向上,把点火钥匙插入左侧的凹槽中
    It works better if the end of the key is placed under the square protrusion in the center area next to the hole for the key. Use the key to gently, but firmly, lever the protrusion away from the main case. You will feel it 'pop' as the back cover comes away.
    Dan Smith - 回复
  4. 2013-2017 款福特汽车钥匙电池更换: 步骤 4 中的图像 1,2 2013-2017 款福特汽车钥匙电池更换: 步骤 4 中的图像 2,2
    • 轻轻地卸下钥匙的后盖
    (See comment above.)
    Dan Smith - 回复
  5. 2013-2017 款福特汽车钥匙电池更换: 步骤 5 中的图像 1,2 2013-2017 款福特汽车钥匙电池更换: 步骤 5 中的图像 2,2
    • 用点火钥匙卸下旧的电池
    I cannot get the back cover off
    Kitty Wolf - 回复
    See my new comment above.
    Dan Smith -
    The key is too clunky to fit next to the battery to pry it out. Use the tip of a pocket knife blade or a pointed plastic spudger to get down into the pocket next the the battery and pry it out. Remember, the '+' side of a new, 2032 battery faces "down" into the case.
    Dan Smith - 回复
  6. 2013-2017 款福特汽车钥匙电池更换: 步骤 6 中的图像 1,1
    • 把新的电池镶嵌进去,”+“面向下,”-“面向下。
    I like to write the current date on the battery with a Sharpie marker, so I know how long they last.
    Place the narrower end on first and 'walk' the cover sides back into the groove, moving back toward the pushbutton end.
    Dan Smith - 回复
结论
要重新组装您的设备,请将后盖更换牢牢固定。
36等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
16条评论
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - 回复
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - 回复
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - 回复
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - 回复
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Joseph Kuperberg - 回复
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Scott - 回复
super easy. Clear simple guide. Took me less than a minute!
dobos_b51 - 回复
That was easy! Thank you for the pictures and the easy to follow instructions!!
rocky752 - 回复
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
Tiffany Nelson - 回复
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
Cathy Hawn - 回复
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Mark - 回复
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Paula Haenchen - 回复
Easy Peasy, Thank you!
Leslie Gaynor - 回复
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
lindasscott1 - 回复
Did all this and does not restart at all lights don’t go on and trunk don’t open
Vicenta - 回复
添加评论
浏览统计数据:
过去 24 小时: 42
过去 7 天: 231
过去 30 天: 1,026
总计 168,795
