跳转到主内容
2012 Volkswagen Touareg Door Lock Switch Replacement
你所需要的
  1. 2012 Volkswagen Touareg Door Lock Switch Replacement, Door Lock Switch: 步骤 1 中的图像 1,1
    • Remove the door pull trim piece using a nylon offset v-notch prying tool.
  2. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the T20 Torx bolt underneath the door trim pull piece.
  3. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the armrest by firmly pulling up on the cover.
  4. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the wiring from the window switch.
  5. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 5 中的图像 1,2 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 5 中的图像 2,2
    • Remove the two T20 Torx bolts that were originally underneath the armrest cover.
  6. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the belt line trim piece carefully with a trim removal tool.
    • This trim can be very brittle.
  7. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 7 中的图像 1,1
    • Remove the T20 Torx bolt that is underneath the belt line trim piece.
  8. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 8 中的图像 1,1
    • Remove the T20 Torx bolt at the very bottom of the door panel.
  9. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 9 中的图像 1,1
    • Use a trim removal tool to release the clips on the bottom side of the door panel.
  10. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 10 中的图像 1,1
    • Once all of the clips are released, use the door pull and lift the door panel off of the top of the door frame.
  11. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 11 中的图像 1,1
    • Remove the tweeter wiring.
    • This plug will be wrapped in a grey styrofoam-like material.
  12. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 12 中的图像 1,1
    • Remove the main door harness from the door control module.
    • This will be a light blue plug with a pink lock.
  13. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 13 中的图像 1,1
    • Now that the wiring is removed from the door panel, distinguish which plug is the door lock switch.
    • It will be located in the top of the door panel. The back of the switch will be blue.
  14. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 14 中的图像 1,1
    • Remove the wiring and use a pick to free the switch of the mounting tabs.
  15. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 15 中的图像 1,1
    • Once the switch is free of the tabs, simply push the switch out from the front of the door panel towards the back.
  16. 2012 Volkswagen Touareg Door Lock Switch Replacement: 步骤 16 中的图像 1,1
    • To install the new switch, just push firmly into the locking tabs until the switch clicks into place.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 64
总计 2,554
