跳转到主内容
2012 Nissan Sentra Rear Taillight Replacement
你所需要的
  1. 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: 步骤 1 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: 步骤 1 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: 步骤 1 中的图像 3,3
    • Open the trunk.
    • Locate the plastic large bolt behind the taillight.
    • This bolt holds the grey cover in place.
    • Remove the bolt with a flat head screw driver or wrench.
  2. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 2 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 2 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 2 中的图像 3,3
    • Peel back the grey cover to expose the back casing of the taillight.
  3. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 3 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 3 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 3 中的图像 3,3
    • Use a small wrench to loosen the two nuts securing the bolts.
    • Locate the group of wires in the center that connect to the bulbs.
  4. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 4 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 4 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 4 中的图像 3,3
    • Once the nuts are loose enough, use your fingers to remove the bolts easily.
  5. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 5 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 5 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 5 中的图像 3,3
    • Disconnect the plug by pressing a button located on the back.
    • This plug will disconnect the taillight from the car.
  6. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 6 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 6 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 6 中的图像 3,3
    • Loosen the sides of the taillight by gently pulling from side to side.
    • Pull the taillight straight out toward yourself in order to easily remove the wires from the small opening.
    • Grab the cord and pull the cord out through the small opening.
    • Place the damaged taillight aside.
  7. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 7 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 7 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 7 中的图像 3,3
    • Wipe down the vacant area and insert the new cord, from the new taillight, through the small opening.
  8. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 8 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 8 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 8 中的图像 3,3
    • Use your other hand to pull the wire inward and lock in the rubber grommet.
    • Make desired adjustments to the front of the taillight in order to have the best placement.
  9. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 9 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 9 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 9 中的图像 3,3
    • Grab the cord and connect it to the outlet.
    • This will allow the light bulbs in the new taillight to work.
  10. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 10 中的图像 1,2 2012 Nissan Sentra Rear Taillight Replacement: 步骤 10 中的图像 2,2
    • Turn on your vehicle.
    • Put the car in reverse or step on the break to test out the new taillight.
    • If the rear lights turn on it means that the connection is intact.
    • Make sure to test both lights.
  11. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 11 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 11 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 11 中的图像 3,3
    • Place the small metal nuts back onto the screws and tighten them with a wrench.
    • Make sure the rubber grommet is intact so that the wires do not backflow into the taillight.
  12. 2012 Nissan Sentra Rear Taillight Replacement: 步骤 12 中的图像 1,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 12 中的图像 2,3 2012 Nissan Sentra Rear Taillight Replacement: 步骤 12 中的图像 3,3
    • Pull the grey cover over the exposed metal and adjust it to its original place.
    • Place and push in the black plastic bolt in order to keep the grey cover from falling off.
结论
This guide includes the reassembling steps so no need to backtrack!
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 36
总计 263
