跳转到主内容
简介
Full replacement of a Driver side mirror on a 2012 Nissan Murano, SL options package.
  1. Pull out the Driver preset panel, if your options package included this. Usually no tools required.
    • Pull out the Driver preset panel, if your options package included this. Usually no tools required.
  2. Expose one of three screws by prying the door handle trim plate out.
    • Expose one of three screws by prying the door handle trim plate out.
  3. Pry out the door lock and window control panel. Disconnect all connectors on the back side. Pry out the door lock and window control panel. Disconnect all connectors on the back side. Pry out the door lock and window control panel. Disconnect all connectors on the back side.
    • Pry out the door lock and window control panel. Disconnect all connectors on the back side.
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Pry up the arm rest to expose the second hidden screw (total of 3).
    • Pry up the arm rest to expose the second hidden screw (total of 3).
  6. Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now the door panel itself can be pried off the door. Starting at the bottom, find the plastic friction plugs and pull enough to pop them out one by one.
    • Then lift the door panel up off the door. You do not need to remove it completly. This should give you enough room to work on the mirror in the next steps.
  7. Pull the inside mirror cover off. Pull the inside mirror cover off.
    • Pull the inside mirror cover off.
  8. Unplug the mirror wiring harness. The connector on the door will stay put.
    • Unplug the mirror wiring harness. The connector on the door will stay put.
  9. Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
    • Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
结论
3等其他人完成本指南。
Gajtguy
于2013年12月15日注册
177 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 42
总计 4,427
