跳转到主内容
2012 Chevy Equinox Tail Light Bulb Replacement
你所需要的
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 3,3
    • Open the trunk of your car.
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 2 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 2 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 2 中的图像 3,3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 3 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 3 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 3 中的图像 3,3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 4 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 4 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 5 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 5 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 5 中的图像 3,3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 6 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 6 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 7 中的图像 1,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 7 中的图像 2,3 2012 Chevy Equinox Tail Light Bulb Replacement: 步骤 7 中的图像 3,3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
结论
Kelly Dixon
于10/13/20注册
145 声望
撰写一个指南
团队
Texas Tech, Team S9-G2, Cowan Fall 2020 Texas Tech, Team S9-G2, Cowan Fall 2020 的会员
TTU-COWAN-F20S9G2
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 37
总计 1,831
