跳转到主内容
2012 BMW 3 Series Windshield Wiper Replacement
你所需要的
  1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: 步骤 1 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: 步骤 1 中的图像 2,2
    • To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
    • This is done to prevent scratches from developing throughout the repair process.
  2. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 2 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to pop the cover off that holds the wiper in place.
  3. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 3 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 3 中的图像 2,2
    • Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
  4. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 4 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 4 中的图像 2,2
    • Install the replacement wiper so that the slightly bent angle side faces the vehicle.
  5. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 5 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 5 中的图像 2,2
    • Check that the screw is aligned with the hole.
    • With a little pressure, slowly slide the new wiper into place.
  6. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 6 中的图像 1,2 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 6 中的图像 2,2
    • Once it is positioned correctly, lock the cover to keep the blade in place.
    • If you hear a click, you will know you have succeeded.
    • Lower the windshield wiper carefully onto the windshield.
  7. 2012 BMW 3 Series Windshield Wiper Replacement: 步骤 7 中的图像 1,1
    • Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
    • You are done if they are wiping properly. If they appear to be loose, make sure they are securely attached before driving again.
结论
Hafsa Yusuf
于09/14/21注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 42
总计 1,020
